You're losing me a bit here. No I cant force the pi to take 20 watts since the system running flat out will draw a maximum of 10 watts with the units I have attached to it. But I can use a resistor in parallel with the pi which will present the panel with an arbitrary load, can I not?
If I cannot do this manually, how does an MPPT charge controller manage to do this with a battery, which has a very low impedance as far as I know?
When you say "Power", are you referring to watts? If so, why does it matter if the input is a voltage or a current source? Power is the product of those two.
Can you show me a few simple math examples with volts and current and power, and what happens when cloudy conditions start to limit the power coming out of the panel?
This would be okay. A system operating without a battery would have to suffer such conditions. With a 40 watt panel I expect the system to keep running in bright and semi-bright conditions. As long as the panel is producing 10 watts and sending that into the buck converter, the pi will not "overload" the input power will it?
I have bought an LVD for different reasons but I had not heard of an UVLO until now. Are those two things the same? As I am reading the specs on such a thing, it cuts off output when the input power drops below a certain point. Which is also what an LVD does.
How would this change things? My pi would still die when a cloud passed by. Just as it would without an UVLO... right?
I actually have a Tracer 1210RN which is an MPPT capable solar charge controller. Is the Midnite Kid the same type of device?
Having a fully fledged charge controller defeats the purpose of this exercise as I am then back to needing a battery of some kind. This is the setup I have now. I want a setup which is much cheaper, to see if simply buying a lot more panel area is more cost effective than setting up a system that requires a battery. Imagine that the pi is producing something valuable, like bitcoins. So every hour of on-time has a certain yield. Will the yield over a year be the same, lower or higher given a $100 system that is based on small panels, an MPPT solar charge controller and a lead acid battery, OR a system which has a huge panel and a cheap buck converter. Also factor in replacing the lead acid battery.
(The bitcoin thing is just an example, my pi won't be generating fortunes for me I understand that
-Michael
-Michael
