North facing Panels
7 degrees was the heading. Angle is 40 degrees.
PVWatts says that the south side will make 2.1x as much power as this side.
That makes a $4.50 per watt system act like a $9.45 per watt system that faces south.
But yeah on angle. My west-facing panels are going to be at 15 degree angle, so I am going to lose about 18% vs a south face. Had they been at a 40 degree angle, I would lose 25%.
The western orientation is going to make my 315 watt panels act as if they are 260 watt facing south.Last edited by rsilvers; 05-10-2016, 09:02 PM.Leave a comment:
I just saw this today. It is facing North at 7 degrees. They also have panels on the south of this shed and of their house. The installer put conduit over and around their gutter. I am going to guess this is not free solar PPA as I don't think any installer would have put panels on the north as it would eat into their profits.
At 7 deg tilt, the penalty for north facing isn't as much as for steeper installations. It is possible that the numbers still come out good enough to justify the choice.Leave a comment:
I wonder if that person would be interested in buying a bridge?Leave a comment:
There are a lot of good things said so far but I have a little different feeling about this.
Given that ROI on PV is kind of low at best when you degrade the output ROI goes way up.
Ask your self if the North facing panels were your only project would you do it.
If you have tiered billing the South array will really cut into your bill and should keep you in the cheep electric rates.
To pay for the North array after your bill is lowered by your South array seems like a real looser.
On the other hand is this a PPA?
If the north array does not produce any electricity what happens to your billing?
Unless your condition is artificially enhanced by the contract I would make them take the North array out of the deal.
They may not even want to come back, remove the array and redo your roof. Get the contract rewritten for just the South array and see how that looks.
Then you may consider a West array but you should evaluate it on its own merritt.
What is the panel name plate rating. You are only getting about 150 watts / panel Something seem really wrong even for your best array. Your inverter seems way over sized.
Seems like you have 260 watt panels producing 150 with great sun. What is you slope? Latitude? Is it getting any better with sun angel change?
What happens if you buy a 11KW system and it works like a 4 KW system?Leave a comment:
Sun out all day in S. Calif. You can see te peak is about 6.8 around 1 pm. This is with one south facing 6 KW system and one north facing 5 KW system. About 5 KW system is from the southern facing panels and 2 KW from the north facing panels.
Based on today's output at this time of year what might I expect in June?Leave a comment:
I would have a Suneye analysis done to find out which has the least shading, east or west. No matter how perfect it looks one will be better. The north panels should be moved ASAP!Leave a comment:
That depends to a large degree on the nature of the cloudiness. Solid, heavy overcast will produce what is mostly isotropic GHI at a flux rate that might be ~ 5-10+ % or so of a clear sky value (say a GHI value of ~ 50 - 100 W/m^2 or so). If the cloud cover is not quite as solid, say with a GHI of ~ 200 W/m^2 or so, the area of the sky around the sun may, depending on the atmospheric conditions, be the source of more of the irradiance. In those situations, often in the morning before the A.M. haze burns off, but other times as well, equator facing arrays may see increased output that could be measurably higher than output from arrays facing away from the equator, particularly if the panels have somewhat better low irradiance performance - some of which BTW and sort of off topic, will be the result of lower operating temps due to lower irradiance.Leave a comment:
