Phtovolatic Panel Wind "Sails" ... :)
Well, those downed panels with their faces turned to the wall of to the ground could certainly still be producing some voltage, but questionably enough current for a hazardous shock. As "storing up a charge until touched", well any sheet of metal can do that, just not very well....
I would have to say that either the racking was underenginieered, the assembly faulty, or the wind load calculations did not take into account the exposed position of the panels. Or a combination of all of the above.
I wonder if anyone checked for tightness of fasteners in the three years since the installation?
What was the last time you saw a solar PV installer employee with a torque wrench?SunnyBoy 3000 US, 18 BP Solar 175B panels. -
Its flat roof, unfortunately they didn't show any roof top views but it could be a ballasted system as many flat roof owners have no interest in drilling holes in the membrane. Tilted panels are particularly vulnerable to odd aerodynamics. Nothing wrong with a properly designed ballasted system but a lot easier to screw up than mechanically fastened.Comment
That appeared to be a Snapnrack installation and it appears that the kee fittings on the top pipe support are what came loose.
And you are right about the torque wrench or lack thereof. It is critical on this type of installation.NABCEP certified Technical Sales Professional
In your experience, is it good enough to get the initial torque correct and let the design of the fittings will take care of the rest, or is are follow up torque checks as part of system maintenance justified?SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Haven't gone back to check but rest assured I will be. Glad I only have about 60 KW installed with that racking system but all on the ground.NABCEP certified Technical Sales Professional
[CENTER]SunLight @ Night[/CENTER]Comment
