Has anyone found lamps which run on DC power? I only see light USB versions which don't generate enough lumens. Looking for a DC powered lamp which takes a typical E26/E27 LED bulb which can be powered by DC to avoid power loss through an inverter.
Lamps which run on DC
Have you looked at the DC tube type? I found some that work off of a battery and produce a lot of light.
Also did you look on amazon? They have DC lamps with E26 bases -
My guess is that just about all DC lamps with E26 bases are low wattage.
The 4 footers that I have may not work for you but they do put out a lot more lumens then those other lamps.Comment
I got some E26 lamps single filament LED on amazon that are 3V. I rewired a table lamp that had three sockets and put them in series. Then added a resistor for additional voltage drop. Carriage light on garage has two sockets and I put them in series and run a buck converter from garage charge controller to make 6V.Comment
I'm sure you can find bulbs like that on sites like Amazon. I got all of my bulbs fro my floor lamps for living room on Amazon.Last edited by Anchyyn; 11-26-2024, 01:04 PM.Comment
