Adding additional panels to existing system, how to figure?
    • 5209
    Originally posted by MGE
    As far as the potential increase of 594w are concerned I made a slight error.
    I meant to say 594kw.
    That does not make sense, maybe you mean 594KWHours? All your energy numbers
    (power times time) need an HOURS unit. Bruce Roe
      ...... I'd also check the city and SDG & E requirements and then call them to see if either one of them thinks rearranging a system layout and orientation as you describe will run counter of some rules (and get the response in writing)..........l
      That is probably a good suggestion, but as readers may have gathered my philosophy is it is easier to ask for forgiveness. I think the city would want to see the usual engineering for the racking that was presumably done on the original install. In my installs, SCE & PG&E only saw a single line diagram with very little detail about orientation. SDG&E may be different and your experience with them is probably more valuable.
      • MGE
        • Feb 2013
        • 152
        Yes Im going to call SDG&E on next week and get confirmation on my proposed changes and will request an approval in writing, if they are willing.
        Looking at my original application for installing my Photovoltaic Generating Facility all they asked for was.
        Inverter Manufacturer Enphase Energy
        Inverter Model # M215-60-2LL-S2x-NA
        Inverter CEC Rating (per unit) 215.0
        Quantity of Inverters 34
        Weighted Efficiency 0.96
        Single or 3 Phase Single
        PV Panel Manufacturer Suniva
        PV Panel Model # OPT-260-60-4-1B0
        PV Panel CEC Rating 232.8
        PV Panel Nameplate Rating 260.0
        Quantity of PV Panels 34
        Total Capacity (kW) 7.915
        Inverter # from above 1
        If I remember correctly they also wanted a one-line-diagram of the proposed install, but no specifics on mounting.
        Nothing was referenced as far as placement, orientation, racking etc.
        See what they say.
          My allIf I remember correctly they also wanted a one-line-diagram of the proposed install, but no specifics on mounting.
          See what they say.
          Thank you.
          My permit/application looks quite similar with additional stuff on my CSI incentive claim form (both from 2013 BTW).
          I'm being a PITA for the sole reason of having been involved in about 150 or so installs in my HOA since ~ 2007.
          I'm the guy in my HOA that gets to review, recommend and sheppard all the PV installs in my HOA, officially for conformance to the CC & R's, unofficially to maybe help prevent or at least minimize the likelihood of my neighbors screwing themselves or getting too badly screwed by vendors (but with very limited success on both counts).
          No way I've seen it alI, but I've seen a lot.
          One common characteristic for my neighbors with PV systems (the ~ 150): The owners want to believe that whatever makes life easy for them is fact, and usually for things like array changes and size bumps the installer reinforces that opinion and tells the owners what they want to hear and to simply skunk it through.
          To be honest about it, my experience is that they (the owners) usually get away with it but the potential consequences are IMO, pretty big, especially (for example) if a fire can be traced to a (faulty) non inspected PV system. Seems like most of my neighbors don't think globally about such things and seem more interested in "getting even" with SDG & E and eliminating most of their electric bill.
          In one particular case of an attempted skunk-through, an inspector spotted a 2 array install location being changed to 1 array of the same size (inspectors are roaming around here all the time - N. County San Diego) and got porky about filing an amended permit because the wiring was being changed around and the inspector claimed that involved some considerations with respect to NEC particulars and circuit breaker sizes and some other things I can't remember the particulars about. He could have red-tagged it and stopped work but the whole thing worked out because (according to the inspector - who in always right) NEC requirements were still met and also because the 2 MPPT's weren't changing size or panels and anyway the inspector was in a hurry.
          Still NOMB and opinion only but my guess is that you'll be told that a 1 kW increase in system size will be OK w/SDG & E and not jeopardize the system's NEM 1.0 status.
          I'm not sure what the city might say, but better to get it resolved than get surprised.
            I don't know if it's good or not, but it does seem to me to have the advantage of propinquity.
            I too appreciate that fortune favors the bold and I generally practice that approach, but I've also found out by example and experience that it can easily slaughter those unprepared along with their brash foolishness who then leave a mess that might have been avoided with a bit more due diligence and professionalism.
            A pinch of foresight vs. a pound of cure or look before you leap type of thing. Take the shot, just be prepared. Sort of like a lawyer in court who always knows the answers before asking the questions.
            Seems better to me to play heads' up ball, do the due diligence up front and avoid the mea culpas afterwards, but I was lucky in having good mentors many long years ago coming up as a P.E.
            Just my $0.02.
              (17) panel group is fine the way it is.
              (6) group panel faces west at 12 degrees giving me an annual projected output of 2.307Mw
              Changing the same group to face south at 22 degrees would potentially give me a generation of 2.571Mw. = +.264Mw
              (11) group panels currently face west also at a 5 degree tilt with a projected annual output of 4.226Mw.
              Changing those panels to a south facing direction and adjusting the tilt angle to 22 degrees would potentially give me 4.714Mw = .488Mw.
              .264Mw + .488Mw = .752Mw
              I feel these changes were I to make them on my own existing system have nothing to do with the Utility companies approval or concern.
              I would not be changing my original capacity specs just allowing for a more efficient system generation.
              But I digress.
              As far as having all that "south facing area availible" thats where the aesthetics reference I made comes into play.
              I made the choice on my own when designing my system to try to blend in my solar arrays to my roof lines and not be an eyesore.
              All Im stating is I could make these changes which would be due to me with no recourse.
              So in using that logic I feel I should be able to add that "projected" value amount when figuring my max 1k add-on.
              Theoretically I should also be able to factor in my existing panels degradation amount from when "new" to present output and add that as well.
              But realistically going by PV Watts projections for my existing home system they come up with an annual output when new of 13.819Mw.
              My lifetime annual amounts for the full years of 2013 to 2022 have avaeraged 12.664Mw giving me a difference of -1.155Mw output per year.
              So I should also be able to factor that value in as well.
              What's your zip ?
              • MGE
                • Feb 2013
                • 152
                Bad news to report.
                I inadvertently used some incorrect wattage values in my postings.
                I used the default value of “ fixed open mount” instead of the “roof mount” in my calculations.
                I just went back through my comments and changed the values to the correct ones.
                I apoligize to anybody who responded to my thread as their comments are now probably inaccurate as well due to my bogus info.
                So….
                In a nutshell.
                Sorry.
                My zip is 92117.
                  Bad news to report.
                  So….
                  In a nutshell.
                  Sorry.
                  My zip is 92117.
                  Understood. Thank you for the info.
                  Off topic: I kept eraser companies working 24/7 throughout my working life.
                    I just did a quick PVWatts run on your arrays.
                    In verifying your modeled output for no more than my own use and curiosity, I used all your supplied system info and then forced the combined model output to match the most recent 8 (eight) years of your array's average output by modifying the system loss parameter until the model's output matched your reported output +/- a few kWhr/yr. (The first year's production or so is usually about 3-5 % higher due to panel burn-in ).
                    FWIW, the system loss parameter needed to be a bit greater than 20 %.
                    Most roof mounted arrays around San Diego match up pretty well with the model by using a 10% system loss parameter.
                    Assuming your supplied data is good, with the 10 % loss parameter, your arrays model out at ~ 14,550 kWh/yr. vs. the ~12,500 kWh/yr. you're averaging now, with that difference being about the equivalent of what 4 X 260 STC W panels in a south facing 22 deg. slope would generate in a fouled condition.
                    My guess is that you're in an area where the panels fouls rather quickly and, like most, yours don't get cleaned except by rain, and, unless you've got a lot of shade, that fouling is most of the reason for the 20% system loss parameter. For a lot of arrays around here, especially near the coast and/or in areas near the freeways or in tightly packed housing or such as in the developing areas along the 56 near the 805 merge with the construction dust, the marine layer and dust combine to form a fouling layer whose runoff is not as easily moved or much affected by gravity, especially on the lower sloped panels such as 2 of your 3 arrays.
                    All that written/said to ask a question: How often do you clean the arrays ?
                    And a comment: With the above thoughts in mind, and unless you've got a lot of shade, if your panels are not currently cleaned by hosing on a regular basis, you might restore something like the amount of production you'd gain by adding 4X260 W panels to the south facing array for the cost of a 20 minute trip to the roof with a hose about 1X/month or so and avoid all/most of the hassles we've been discussing about permitting and such.
                    At least it might be worth a trip to the roof on a regular basis as an experiment. what have you got to lose ?
                    • MGE
                      • Feb 2013
                      • 152
                      I used to regularly clean my panels maybe every other month at first and then unfortunately tapered off since then.
                      My first year was my best at 13.268Mw hrs.
                      So I realize that I am leaving $ on the table to some extent.
                      So I want to add my additional panels to recapture my projected “Max” output potential.
                      Will I actually change the arrays that are facing W, probably not, but I will figure those losses into my projections on the new string.
                      Probably will be adding technically more than 1k in new production to help recoup my less than producing existing panels.
                      We’ll see what the Utility Co. says this week.
                      • MGE
                        • Feb 2013
                        • 152
                        Good news is I spoke to a rep by the name of James in the solar planning dept. at SDGE.
                        I asked him if it was ok to change the azimuth and tilt angles of my two arrays ( same string ) to the S at 22* using and not changing the wiring, racking type etc. and he said no problem as it sounded like I had been leaving some production on the table for 10 + years.
                        So it looks like I will be gaining that amount as well in theory as well as the addition to of the 1k.
                          Well, that is good news.
                          Congratulations!
                          Between the reorientation of half your system to the more favorable orientation and the addition of ~1 STC kW of panels you'll probably be picking up about 3,000 - 3,500 kWh/yr. of production even if you don't hose the array.
                          Hose the system down 1X/month if it doesn't rain, especially in the summer and add a few % to the annual production on top of that.
                          As long as you've done the due diligence this far, I'd respectfully suggest you consider checking with the city for any permitting issues that they might have. The POCO and the permitting authority both need to be covered.
                          • Calsun
                            • Oct 2022
                            • 91
                            How much to add is dependent on the capacity of your inverter and whether you want to replace it. In California any system upgrades are on hold at the PUC has allowed the three utility monopolies to change the metering program in an effort to kill private solar ownership by their customers.
                            The utility in Hawaii with the Oahu Rule was successful in killing solar in that state and driving 90% of the solar installers out of business. Our PUC is a captive agency and it does not help that our governor Gavin Newsom, is corrupt and duplicitous.
                            • MGE
                              • Feb 2013
                              • 152
                              Inverter size is a non issue as I used micros.
                                Originally posted by Calsun
                                ....... In California any system upgrades are on hold at the PUC has allowed the three utility monopolies to change the metering program in an effort to kill private solar ownership by their customers.
                                It is not true that system upgrades are on hold in California at the CPUC. Each of the three Investor Owned Utilities processes system upgrades for their customers and there is no restriction or hold on those upgrades. I agree the current rules under NEM 3.0 are not as favorable as NEM 2.0
                                it should also be noted that there are at least a dozen Municipal Utilities like SMUD and LADWP and others that are not regulated by the CPUC.
