Pls help! Solar system dead for 2 months and nobody will help
  • davidcheok
    • Dec 2022
    • 99
    #31
    Originally posted by otherchuck
    OP again.
    Should I remove that water? Any idea how I can do that?
    Otherchuck
    I think you can use a blower to blow out the excess at the very least. If you can leave a blower to blow dry air into the pipe for at least an hour, it should remove most of the water.
    Think the tech would know the whole point of those pipes if to prevent/minimise contact with water and having the pipe and wires submerged in water is all kinds of wrong.
    • Mike 134
      • Jan 2022
      • 429
      #32
      Underground electrical pipes get water in them. Even supposedly glued together PVC conduits. Up here if for example a parking lot light needs to have new wire pulled to it, we'll wait till spring when the ground thaws. I've never pulled out underground wiring and not come away with soaking wet gloves.
      • davidcheok
        • Dec 2022
        • 99
        #33
        Yeah which is why our standards here is to always minimise joints on conduits. However, having a little bit inside vs an entire filled pipe changes the risk profile substantially. I suppose you guys have it worst with frozen grounds. If pipes with water were frozen, think those will just crack. Anyway, if it were me, as i said above, I would blow out the water as much as possible. You have your own standards and procedures over there.
