Hey guys,
EDIT: I realize the title doesn't make much sense lol - I don't see a way to change it, so what I really should have titled it was "Am I oversizing my system by too much?"
I'm in contract with a local company to install solar on our roof here in Southern CA (under SDGE). They initially sized me out with a 15 panel 6kw (generating 9017kwh/yr) system. I was thinking it might make sense just to maximize the install on that side of the roof and after the site survey they were saying I *could* install 19 panels on this roof section - that would increase the size to 7.6kw (generating 12,000+kwh/yr).
Our current usage estimate (we haven't lived here a full year) is in the 7500kwh/yr ballpark. But I was thinking upsizing might be good as far as "future proofing" our needs (like if we get an EV/charger or two, moving towards more electric appliances, adding a minisplit or two possibly). We are planning to have our new HVAC system installed (our furnace is dead) in October and this system I think is roughly twice as efficient (4ton/15-16seer) as our current (4ton/probably 7-8seer) so I'm pretty sure our kwh usage will actually go down once that system is in place.
Do you guys think I'm grossly oversizing the system and that I should just stick with the 6kw proposal? SDGE charges the highest rates in the nation as well. In terms of adding more panels later, t seems like it's a bit of a pain to go through all that as it involves permitting and is then subject to any new NEM changes etc. I was also considering a battery but may hold off on that (btw: would battery additions to a solar system cause you to lose your "grandfathered" NEM status?)
