True-Up Date
  • Just Steve
    • Mar 2022
    • 20
    True-Up Date
    So in the NEM contract with my POCO I will have a one time chance to change my true-up date, I live in mid state NY, is there a particular date that would be of benefit to me. Such as after winter before peak generating season or something else, I figure you folks that have had solar for awhile have this strategy figured out.
    Thanks
    Steve
  • Mike 134
    • Jan 2022
    • 432
    following
    • oregon_phil
      • Jan 2019
      • 497
      I collected two years worth of data before adjusting my annual true up date. My system generates 92% of my annual usage. I adjusted my annual true up month from March (default with POCO) to February. In the willamette valley in Oregon, December, January and February are bad generation months; March is when it starts to get much better. In some years, February is when my net metering balance goes to zero.
        • 5209
        Best time depends entirely on when you generate the most,
        and when you use the most. Probably best is shortly after
        you start generating more than you use. Here I generate a
        surplus of some 14,000 KWhour in summer months, then
        gradually use most of it up heating in winter. I start making
        more than I am using about beginning of March, true up is
        beginning of April. Bruce Roe
        • oregon_phil
          • Jan 2019
          • 497
          Well said. That's what I was trying to say, but failed to say it.
          If you consistently generate more than 100% of usage, you're not going to care about true up month. If you generate much less than 100% of usage, you have a larger margin for error on picking the "correct" true up month.
          My situation, at 92% of generation vs usage and having net positive generation in March allowed me to bank several hundred kwH instead of giving them to POCO. Also, for my POCO, "March" means the end of the March billing cycle, not March 1st. In my previous post, my "February" true up date is actually the end of the February billing cycle which turns out to be February 28th.
          • Mike 134
            • Jan 2022
            • 432
            Bcroe and I both are ComEd customers in northern Illinois. A better term for us is POOF date, either October or April. any excess you have goes poof at the end of the 12-month cycle. You cannot carry it forward into the next 12 month period. But it is a true one for one credit per KWH.
            • Just Steve
              • Mar 2022
              • 20
              Without waiting to see how much I produce as I can get a general idea using PV Watts, would knowing my average consumption help figure this out? 2020 and 2022 were abnormaly high due to extra people living and working from home due to COVID. My annual average is between 12 &13,000 KWH with June, July and August being the highest.
              Date KWH
              Dec - Jan 2017 824
              Jan - Feb 2017 813
              Feb - Mar 2017 687
              Mar - April 2017 534
              April - May 2017 1012
              May - June 2017 917
              June - July 2017 1771
              July - Aug 2017 1450
              Aug - Sept 2017 1683
              Sept - Oct 2017 763
              Oct - Nov 2017 700
              Nov - Dec 2017 875
              Dec - Jan 2018 873
              Jan - Feb 2018 481
              Feb - Mar 2018 569
              Mar- April 2018 714
              Apr - May 2018 932
              May - June 2018 1151
              June - July 2018 1556
              July - Aug 2018 2624
              Aug - Sept 2018 1141
              Sept - Oct 2018 1570
              Oct- Nov 2018 735
              Nov- Dec 2018 886
              Dec - Jan 2019 722
              Jan - Feb 2019 1129
              Feb - Mar 2019 577
              Mar - April 2019 895
              April - May 2019 1110
              May - June 2019 669
              June - July 2019 2090
              July - Aug 2019 1600
              Aug - Sept 2019 1265
              Sept - Oct 2019 1017
              Oct - Nov 2019 736
              Nov - Dec 2019 887
              Dec - Jan 2020 987
              Jan - Feb 2020 499
              Feb - Mar 2020 760
              Mar - April 2020 988
              April- May 2020 859
              May - June 2020 1603
              June - July 2020 1783
              July - Aug 2020 2978
              Aug - Sept 2020 1103
              Sept - Oct 2020 1841
              Oct - Nov 2020 664
              Nov - Dec 2020 786
              Dec - Jan 2021 842
              Jan - Feb 2021 2907
              Feb - Mar 2021 842
              Mar - April 2021 1268
              April - May 2021 1052
              May - June 2021 1519
              June - July 2021 2618
              July - Aug 2021 2454
              Aug - Sept 2021 1350
              Sept - Oct 2021 1403
              Oct - Nov 2021 689
              Nov - Dec 2021 1455
              Dec- Jan 2022 743
              Jan - Feb 2022 1794
              Feb - Mar 2022 959
              • Mike 134
                • Jan 2022
                • 432
                How much does the power company pay you in NY for your excess? Same as you pay to buy? Is it a real true-up (you pay/they pay) or just a starting point for a new 12 month cycle. What happens to any credits you have with the new 12 month calendar?
                • Just Steve
                  • Mar 2022
                  • 20
                  It's a use it or lose it plan, carry over month to month then poof after 12 months.
                  • Mike 134
                    • Jan 2022
                    • 432
                    Since I had an either of April or October I went with April. Though behind that Jan-Feb-Mar has the least amount of sun, the sun's lower angle, some days covered in snow. Those conditions would likely use up any excess credits I had from the cooler fall months.
                    • oregon_phil
                      • Jan 2019
                      • 497
                      Your annual average is closer to 14,000 to 15,000 kW excluding 2020 and partial year data provided. I took Jan-Feb to mean usage during January.
                      kwH Usage
                      2017 2018 2019 2020 2021
                      January 813 481 1129 499 2907
                      February 687 569 577 760 842
                      March 534 714 895 988 1268
                      April 1012 932 1110 859 1052
                      May 917 1151 669 1603 1519
                      June 1771 1556 2090 1783 2618
                      July 1450 2624 1600 2978 2454
                      August 1683 1141 1265 1103 1350
                      September 763 1570 1017 1841 1403
                      October 700 735 736 664 689
                      November 875 886 887 786 1455
                      December 873 722 987 842 743
                      Usage Annual Total 14095 15099 14981 16726 20321
                      In your other post, you gave a range of PV Watts generation estimates. Depending on your actual PV generation and actual usage, you might be well over 100% (don't care which month) PV generation/Usage or in the 80 to 90% range (starting to care which month).
                      PV Watts Estimate
                      Low PV Estimate 17089 17089 17089 17089 17089
                      Middle PV Estimate 17803 17803 17803 17803 17803
                      High PV Estimate 18400 18400 18400 18400 18400
                      PV Generation/Usage %
                      Low PV Estimate 121% 113% 114% 102% 84%
                      Middle PV Estimate 126% 118% 119% 106% 88%
                      High PV Estimate 131% 122% 123% 110% 91%
                      I think you need to take actual data for a couple of PV generation cycles given you have one chance to change true up month.
                      • Just Steve
                        • Mar 2022
                        • 20
                        kwH Usage
                        PV Watts Estimate
                        Thanks for breaking out the info like that, gives me a great visual. When you say "couple of PV generation cycles" what do you mean by that? A couple of months? or something else?
                        Thanks again.
                        • oregon_phil
                          • Jan 2019
                          • 497
                          I gave myself two years to figure it out, but that's just me. Variables: New solar panels are super clean (maybe higher than average output), year to year PV generation and usage variation, other unknowns.
                          1) Estimated average PV generation using PV watts for your Zip code. This is only an estimate because I didn't know your actual panel count and how many 60deg and 240deg.
                          2) Your usage history
                          If you only have one chance to make the true up month change, the more data you can take, the better. Actual PV generation data is better than PV Watts estimate. I have some years better than PV Watts estimate and some years worse than PV Watts estimate. Overall, PV Watts is pretty close for me. On the other hand, my usage requirements have changed due to wildfires, ice storms, and other unknowns.
                          Good luck!
