Hi Guys,
Please can you assist me - I'm looking to get a 5kv Sunsynk inverter, a 5.5kw Hubble battery, and solar panels. My monthly usage is 400-500 kW units.
For the solar panels, i have contacted two installers and each recommended different solar panels.
The one installer recommended 8 x 455 solar panels (one single string) and the other recommended 8 x 540w solar panels (2 strings of 4 each).
The 540w panels do produce more power and will hopefully not need to buy more panels in the future, but I have concerns that these might not be the optimal panels for the invertor. However, with the 455w, I will have an extra string to fill up in the future.
Also if a add another 5.5kw battery in the future - would I need to get additional panels depending on the panel I choose?
Not sure which solution would be the best optimal solution? would really appreciate your views and recommendations.
thanks
thanks
