Victron Cerbo GX
  • ShedPower
    • Apr 2022
    • 29
    Victron Cerbo GX
    Hi
    i have an automatic transfer switch on my system which is great but it only transfers to grid power when battery voltage drops to eg 12.2v. However, this means you can turn off the inverter or a fuse blow to the inverter and it won’t transfer to mains if battery voltage is still above 12.2v, even if it’s receiving no power from the inverter.
    I’ve been looking at the Victron Cerbo GX and it has two relays to switch something on or off when a criteria is met. Does anyone know if this can be used to switch over to the grid if there is no output from the inverter?
    thanks.
