i have 28 sunpower 335 panels, with solaredge inverter with optimizers - recently when i check the production, most of the panels are in the 310/325 range... BUT some of them show they are producing 500-550, i saw 2 up at 650 - it is a monitoring problem or something else?? thaniks
sunpower 335's overproducing
How long do the output levels > 335 W last ?
However long they last, or unless you have a lot of irradiance augmentation from albedo, outputs > say, 400 W or so are probably monitoring anomalies. -
Definitely a monitor problem. Bruce Roei have 28 sunpower 335 panels, with solaredge inverter with optimizers - recently when i check the production, most of the panels are in the 310/325 range... BUT some of them show they are producing 500-550, i saw 2 up at 650 - it is a monitoring problem or something else?? thaniksComment
