Hi all,
I need some advice on whether the output of my systems seems to be performing up to par. I would seem to me that it is not, but I have very little experience in this area and am looking for guidance / help. I recently took the plunge into a Tesla Solar Glass roof (v3) and 2 Powerwalls. In general, I love it. Beautiful roof and keeping me mostly off grid. We maxed out the roof and I was told that the system would rate at 12.98kW. This equates to 222 PV roof tiles. Here are the specs for the tiles:
At 25 degrees C:
Voc (v): 13.34
Vmp (v): 10.99
Isc (A): 5.65
Imp (A): 5.32
Pmax (W): 58.47
Temp coefficient:
Voltage at open circuit: -0.299
Max power: -0.395
Short circuit current: 0.047
Using the Tesla app I observe the following. I live in S. Calif. and summer is kicking in. My roof is not shaded. Tiles are installed on both North and South facing roof angles. At mid-day, and to a couple hours on either side, the sun hits both N and S surfaces and is unobstructed.
This seems to be a really huge swing. It seems that the temperature coefficient should account for only about a 20% drop. Factor in some general loss in the system itself, and I would think that it should be producing about 9.75kW sustained on a really hot day, at a minimum. But I may be looking at this wrong. That is where I am looking for advice for you.
I cannot be 100% certain if they actually put up 222 PV tiles as the roof seems to be too slippery for me to go up and count them
Any thoughts, advice, direction would be hugely appreciated!!
John
At 25 degrees C:
Voc (v): 13.34
Vmp (v): 10.99
Isc (A): 5.65
Imp (A): 5.32
Pmax (W): 58.47
Temp coefficient:
Max power: -0.395
On hot days (outside temperature of 90+F) I have observed the system producing a maximum instantaneous output of 8.2kW. Hotter days I have seen less. This is at 12:30PM
On cool days with clouds that part momentarily to let through the sun, I have observed up to 12kW instantaneous output. But in general on cool days I observe somewhere in the 9.8 to 10.5 kW sustained instantaneous output.
John
