Off Grid - 6v DC adapter wired to 6v led light
+ More Options
Posts
  • max2k
    • 819
    Originally posted by drewola
    NEOH thanks, that solves alot of issues for me. I assumed 110 would use more energy than 6. If the voltage has no bearing in power consumption, then I'm wasting my time, and will go with the lower wattage bulbs as you suggested.
    Power = Voltage x Current that's all to it.
    Now light bulb technology has a lot of effect on how much light a bulb will produce: incandescent will use about 5% of its rated power to produce light, the rest will go into heat. LED will use 30-40% of its rated power to produce light which allows to use lower wattage 110V LED 'bulbs' to produce exactly the same amount of light as their incandescent counterparts saving a lot on your electric bill / battery capacity. You just need to pay attention to additional characteristics of LED 'bulbs' - color temperature and color reproducing index (CRI). I personally prefer 2700K and CRI > 90%. With such parameters I am unable to distinguish LED from halogen bulbs which are considered the closest match to sunlight.
