Creek in the way!??
  • Castironpan
    • Oct 2015
    Creek in the way!??
    Looking at installing a ground mount. The location of the ground mount is approximately 400' away from the Main Panel. The problem is that half way through the trench there is a seasonal creek. It is dry now, but I am curious what issues I will run into with this? I have a feeling it is going to be a headache and would like to be prepared before I start working.
    Any ideas?
  • Living Large
    • 910
    Any ideas?
    What kind of issues are you anticipating? Regulatory? Technical?
      If you disturb the bottom of the creekbed, expect some agency to get upset if they see it.
      I ran a cable suspended conduit over my creek. A solid anchor on either side, 3/8 steel cable, and hung the conduit with hose clamps from the cable.
      This carried my 1.5" drinking water line, electrical service and 2" irrigation water lines for 4 years, but it eventually built a bridge to be able to insulate the water lines because they keep freezing up (sch 80 poly tube).
      My seasonal creek is 30' deep and 60' wide, we call it the Grand Canyon.
      photo album of bridge placement, some shots you can see the cable bridge alongside the new $$$ bridge. Wife wanted running water in winter......
      The bridge is at tree top level of trees in the bottom of the creek, I had to saw tops off to get the bridge in, you can see the cable next to me.
      • Castironpan
        • Oct 2015
        Both. I am unfamiliar with any code that is relevant to this specific situation when it comes to electrical conduit. And I am sure there are some regulatory things I will run into, I am just looking for an Idea of what that might be prior getting yelled at by some building department or environmentalist group. Part of me just wants to dig through it and pretend it doesn't exist.
          • 15160
          I suggest you dig really deep or go over the creek. By the way water will ALWAYS find a way to get into a pipe at a couplings or fitting. Even sprinkler pipes leak. So the wires will get wet.
          • foo1bar
            • 1833
            AFAIK there isn't any NEC issue with being underground under water. But you'll want to make sure the cables going through the conduit that you bury (or suspend) are in good shape - no nicks in the insulation or anything.
            Whether there's issue with digging/trenching in a waterway - that's something that depends a lot on your state and what kind of waterway and how they treat it. (and also whether there's anyone that would see it that anyone would even know)
            • Living Large
              • 910
              You did not list your state (if US) or the feds. I am crossing a creek in NYS, and had to go through the DEC (state regulator) and US Army Corps. In my case the creekbed is owned by others. The water itself is state or government owned. Do you own the land on both sides of the creek and the creekbed? Any wetlands? Floodplain?
              Regulatory agencies are concerned about what material may flow into the creek as a result of excavation/fill; if the creek water would be diverted (unlikely in your case). Also disturbance of wetlands, as applicable. Where are you located (state, etc)?
              • Living Large
                • 910
                That is an impressive project, and well documented. Others here may have previously seen it - I had not.
