Somebody told me the easiest way to find out where your solar panels should be pointed was to go outside at noon and stick a dowel rod into the ground, adjust it so it cast no shadow, and point your panels in the same direction.
Or, point them south (for northern hemisphere) and angle them at whatever the longitudinal is line for your location. For example, google earth says I live @ 37N, so I would point them south and tilt them at 37 degrees.
Which one do you think would work better?
Do you have another method that doesn't require a degree in mathematics and astronomy?
