Charger controller rating vs inverter rating
  • Sunny Solar
    • 510
    65KWH IS ONE STEP BEYOND INSANE. 1950kwh a month give or take a kilogram.
    Im at complete loss to know how some people live.. mabe im just a mean user of electricity.??
    but my electric bill is under 400kwh a month.
    300l fridge. one x1hp split aircon on every night 10 hrs . 10 12w CFLs and 8 5w LED 240v lamps but they run off solar..
    50"TVon about 8 hrs a day. Auto 7kg washing machine used 2 times a week.(40 mins a cycle)
    Have another 21/2 hp split air con used about 6 hrs a week.
    Thats it.
    Gas stove used every day and solar oven used boil water and cook rice most days.
      Originally posted by Stoppy
      It is 80 amps. This project will never be built and pure fantasy from someone who has no clue what they are doing.
      • Stoppy
        • Mar 2015
        • 10
        The max charging current is 80A, so you cannot add a fuse or breaker of 80A rating, the next available breaker ratings is 100A, got it?!
          I have 35 years experience in EE and a PE. Your instructors has never designed or built anything. That is why they teach. Got it? You are just a student who has never done anything. If you had you would know you have a disaster on paper.
            • 15159
            The maximum output of the charger is 80 amps. Putting a larger fuse on it does not get you more amps out of it.
            What you are thinking is the same as saying I still have checks in my checkbook so there must be money in the bank to cover them.
            The only way to get 100 charging amps is to use multiple CC connected to the same battery bank.
              ...The maximum output of the charger is 80 amps. Putting a larger fuse on it does not get you more amps out of it....
              I suspect that all he is saying is that if the 80A output is continuous then the NEC would require branch circuit wiring and OCPD to be rated at 1.25 times that or 100A unless 100% rated equipment is used. No implication that you would ever actually see 100A.
              Once can argue that the same provision also applies to DC circuits over 50V.
                • 15159
                Ah. I get it. The wiring diagram was showing a fuse rating not the CC output.
                • Stoppy
                  • Mar 2015
                  • 10
                  • Stoppy
                    • Mar 2015
                    • 10
                    Man who told u I want 100A from the charger controller????!! I'm happy with 80A. The 100A breaker it's just for protection
                    • Stoppy
                      • Mar 2015
                      • 10
                      Exactly! thank you!
                      • zaki
                        • 4
                        Originally posted by Sunny Solar
                        The schematic shows ALL the batteries in parallel. ???
                        Trying to ever balance 24 batteries in series parallel will be the most fun you will have for a very long time to come. Would have been far easier to have used 12 batteries with double the capacity..
                        Der Versuch, mehr als 24 Batterien parallel Serie Balance wird der größte Spaß, sein, gut, du hast Recht.
                        Villen Dank
                        <sales site link deleted>
                        ---Mod Note:
                        Zaki,
                        Your posting behavior is going over the line of what is acceptable in this Forum.
                        Please be more responsible or face disciplinary action.
                          Villen Dank
                          Trying to more than 24 batteries in parallel series balance is the most fun to be , well , you're right.
                          Thanks villas
                          Please, use google translate for your posting to this english forum. Much easier for you (1 person) to do this, than for many people who would be interested in your post, but don't bother with translating.
                          Thanks
                          Bitte verwenden Sie Google Translate für Ihren Beitrag zu dieser Englisch -Forum. Viel einfacher für Sie (1 Person) , dies zu tun , als für viele Menschen, wäre daran interessiert, Ihre Post , aber nicht mit Übersetzungs stören.
                          Danke Shon
