Hello,
I am comparing my options for inverters for a grid-tie PV system using 10 230 W panels. This DC wattage would seem to call for an inverter rated for 2000 W AC or higher. Fronius and PV Powered make 2000 W AC inverters, but two of the manufacturers that seem to be frequently recommended in this forum (SMA and Xantrex) seem to start out at 2800 W AC or higher. My question: are there any drawbacks to having the DC wattage at the lower end of the rated capacity for an inverter? For example, using a 2300 W DC panel array with a Sunny Boy 3000? I understand that there will be a cost difference between inverters rated for lower or higher wattage, but are there also efficiency concerns?
Thanks!
Thanks!
