So if I have a 200w panel and a 20amp mppt charge controller would that not put too much power into say a 20AH 12v battery.
I mean I read that you generally should charge a battery at a quarter it's capacity. So a 100AH battery would be charged with no more than 25amps.
I know that high voltage causes gassing but also too many amps cause overheating and ruin the life of the battery.
So if I connected my 20AH battery to the 20amp mppt controller which is connected to a 200w panel would it pretty much be a bad idea since the mppt drops the voltage to 13.6 or so which is fine but it also raises the amps to preserve the power of the panel and would feed around 14amps into the battery which would be far too much.
According to the batteries AH rating I should only charge it at 5amps actually. But you can't hook up a 5amp charge controller to a 11amp or so large solar panel right? I am pretty sure you have to match it or you ruin the charge controller.
So what is the best way of charging a smaller battery.
