Electric space heaters to use up excess production?
  • Mb190e
    • May 2014
    • 167
    I just had my solar system installed last week. I had one of the companies they gave me a quote say that they use electric space heaters in the winter to use up extra production does anybody else do this?
    Excess production in the winter? What was the salesman smoking?
    If so then your system is grossly oversized for summer!
    • Mb190e
      • May 2014
      • 167
      To start off by saying my system is oversize slightly we are on the lower end of electric consumption. We use roughly 6000-6500 kWh a year. For a 2300 square-foot house family of 3. We installed and 8.1 kW system. Future plans of possibly getting solar hot water with a heatpump and/or Hot tub. Our utility does net metering where all kWh credits are settled once a year. So what I heard was if you have extra credits instead of giving them back to the utility for a penny's a kWh, use them up by heating a couple rooms with electric space heaters. I'm new to this solar PV I have only had my system for running for 5 days.
        where are you located?
        • Mb190e
          • May 2014
          • 167
          Saratoga, NY
          • billvon
            • Mar 2012
            • 803
            That's a bit below average.
            In Saratoga you're going to be seeing about 3 kwhr/day average production from a 1kw AC (1.2 kw DC) system. So that's about 20kwhr/day average. Could be slightly more or less depending on array angle, roof temperatures etc.
            I would definitely not try to "waste power" until you have about a year of data showing that you really have the extra power. A week of clouds can easily end a long run of overproduction and drive you back into electric-bill territory very quickly.
              From PV Watts for a site close to you
              RESULTS
              3.19 679 102
              3.69 712 107
              3.66 731 109
              3.94 728 109
              4.78 908 136
              4.07 719 108
              4.63 839 126
              4.56 840 126
              4.23 743 111
              3.60 686 103
              2.72 519 78
              2.14 424 64
              3.77 8,527 $ 1,277
              Find A Local Installer Download Results: Monthly | Hourly
              Caution: Photovoltaic system performance predictions calculated by PVWatts® include many inherent assumptions and uncertainties and do not reflect variations between PV technologies nor site-specific characteristics except as represented by PVWatts® inputs. For example, PV modules with better performance are not differentiated within PVWatts® from lesser performing modules. Similarly, the “Energy Value” column simply multiplies the utility-average electricity price by production. Complex utility rates and financing can significantly impact the energy value. See Help for additional guidance.
              Requested Location saratoga, ny
              Weather Data Source GLENS FALLS AP, NY (TMY3)
              Latitude 43.35° N
              Longitude 73.62° W
              DC Rating 8.1 kW
              DC to AC Derate Factor .82
              Array Type Fixed (open rack)
              Array Tilt 43.0°
              Array Azimuth 180°
              Average Cost of Electricity Purchased from Utility 0.15 $/kWh
              Cost of Electricity Generated by System 0.28 $/kWh
              These values can be compared to get an idea of the cost-effectiveness of this system. However, system costs, system financing options (including 3rd party ownership) and complex utility rates can significantly change the relative value of the PV system.
              • Mb190e
                • May 2014
                • 167
                Ok thanks, my Tilt: 33° Azimuth: 178°. I have also turn this into somewhat of a game since signing the contract for the solar panels I've also cut the cord on our DirecTV, just by unplugging 2 DVR boxes, power injector and multiroom router. It has saved me 150 watts an hour. That should equal another kilowatt a year. I just hung up my first clothesline ever. I'm attempting to dry as many close this summer via clothesline that I can. I'm pretty excited about this new adventure as of this message we have generated 136 kWh's since May 1 and it's been mostly cloudy and rainy the last 4 out of 5 days. I may have a new high today.
                  • 5209
                  Space heater
                  Something like that is happening here. I have a big permanent electric heater
                  with a thermostat, for zone heating. Its in half the basement, heat will rise to
                  rooms above. I put a couple space heaters on the concrete floor at the other
                  end, not near anything flammable. These can be turned on to use excess
                  energy. If things get too cool, the lower set propane furnace thermostat cuts
                  in. However, it hasn't run in a couple months.
                  The plan is to have sufficient baseboard electric heaters to take care of
                  everything, each area with a local thermostat. If electric energy runs out,
                  they can be set lower and the propane furnace takes over. Bruce Roe
                    rooms above.
                    For excess production that is not a problem but you need the heat when production is lowest. Electric radiant heat has a COP of 1 - meaning 1 kW of electricity produces 1 kW of heat. As bad as it can get!
                      • 5209
                      Right, but Mb190e mentioned net metering settled once a year. KWH burned off in the
                      cold might have accumulated in the summer, which is my plan. We both are looking
                      at a heat pump as well, some of the KWH might do a better COP than 1. Bruce Roe
