I have been working on a more "green" focus for life here in Tucson, and the latest change was buying a Plug-In Prius. Love it!! It's a hybrid but it can get "999 mpg" (use about 4kWh of electricity instead) for any trip under 10 miles, which is lovely.
I have toyed with solar panels for a recharging system for an RV in the past, but that was easy because the "coach" batteries on an RV are basically the exact same animal as those in a small solar system anywhere. What I want to do now it throw a couple of solar panels on the roof of the carport and charge the Prius with them, which doesn't seem quite as simple.
The fully charged battery on the Prius is approximately 4kWh, it's designed to plug into a household 110 outlet and takes 3-4 hours to charge. I don't know what kind of amperage it draws. I have a 2000 watt inverter. I guess the big question is, does anyone know if I need a separate battery (i.e. panel-battery controller-battery-inverter-car) or could I get away with panel-inverter-car. (the car has a "shut off" when the battery is charged, so maybe don't need a separate controller in this scenario?). Does anyone know if the car needs a constant stream of energy vs a trickle charge? I don't.
I'm ok with waiting for the sun (trust me, Tucson is not lacking in sun), I don't need to charge the car at night. If I need a separate battery, do you think it would be possible to go with a smaller capacity than 4kWh, as the panel should be recharging the battery at the same time the car is drawing from it, or will this put too much strain on the battery?
Any creative thoughts or advice appreciated, TIA!
Karen
Karen
