energy saving tips
This would be a great help for me, I have increasing electricity bills and I don't know how to lower the price of my bills. I follow the tips of this saving energy. Thanks for this post.Comment
There are many tips for saving energy at home it start with our self disciplined first and most importantly, off the whole electric things after using it. In addition, try to use natural way of lighting.Comment
Start here
The best energy saving tip I can give is to buy all high efficiency appliances. I did that and changed all my lighting to CFL and florescent, and I cut my electric bill by 40%. I also installed a high efficiency gas furnace and gas water heater and that cut my gas bill by 45%. I also added insulation in my attic. The way I see it, that was the first step in going solar. This all needed to be done BEFORE getting a grid tied solar pv system, otherwise I would just be wasting the energy I produced.Comment
Anyway, there are some methods and techniques on how to save energy specifically at home. And I think this methods helps a lot for the some consumers. Saving energy at home is just like saving our Mother earth. Moreover, you can save energy at home by maintaining switching off the light after you use it and most importantly, you can reduce using some appliances who did not really important at home.Comment
Energy Conservation
I am just starting this as a topic on my blog. Would mind if I quote you?
I agree. Conservation is going to be at least as important as finding new energies.
Thank you for posting this.
Lisa
Hi,
There are some tips which can save energy.
According to the Department of Energy, a programmable thermostat can reduce your heating costs by up to 35% and cooling costs by up to 25%. If your home sits empty a good part of each day, consider investing in a programmable thermostat or manually adjust the temperature each time you leave and return home.
Close curtains on south- and west-facing windows during the day.
Plant tall, fast growth trees on the south side of your house.
Install white window shades, drapes, or blinds to reflect heat away from the house.
Replace standard incandescent light bulbs with compact fluorescent light bulbs (CFLs).
Unplug electronics, battery chargers and other equipment when not in use. Taken together, these small items can use as much power as your refrigerator. Televisions, cable television boxes, cell phone chargers and other electronics give off more waste heat than you might imagine. Unplug these items or consider purchasing power management devices to eliminate electric consumption entirely when not in use.
If you have a mechanical air filter or HEPA filter inside your heating and cooling system, have an air conditioning and heating technician replace the filter annually.
Allow air to circulate around your outside condenser unit. Fallen leaves may hinder the efficiency of the air conditioning unit so make it a habit to clear your air conditioning units with fallen shrubs. This means pruning any nearby hedges and keeping the grass mowed. Treat the area for fire ants, as needed. Ants commonly build mounds inside condensers and can cause your air conditioning to shut down.
Mod note - links are generally not allowedComment
Originally posted by energychoice014Before your post, I thought if we remove our mobile phone from charging and our light switch still on, then it behave like open circuit and current does not flow in open circuit according to the physics law. But according to your post I was wrong.
Appliances which stay powered up enough to run the remote control receiver and internal computer take a lot more.SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
Originally posted by Sharon_brunettiYes, newer chargers like those made in the past 4 years donโt draw as much power. Still, it would be best to just unplug them as they could also become risks especially if the cord is all over the floor or desk.MSEE, PEComment
Around Christmas time, look for the inexpensive wireless remote units that they sell to turn on and off Christmas lights. (Like $25 for a 3 A/C unit controllers and battery operated remote). I have a 3 unit remote controller on the table by my easy chair that I can turn on, or off, most all of the units in our entertainment center, via a power strip, plugged into the remote control A/C plug in unit. So all those power draining devices, that are them selves remote controlled, such as our DVD, Blue ray DVD, old VCR, Stereo, Old cassette Tape deck, and even our powered sub woofer, are all now on a single power strip, plugged into a single remote A/C unit, that I can remotely turn on, and off, from my easy chair when we need to use them. The sub woofer alone was using 15 watts to just sit in "stand by" mode, all combined it was draining 45+ watts per my kw meter, 24 /7. I have another A/C remote on a light, and even one for our gas log fireplace fan, where the gas log, is also remote controlled, from a remote by my chair. (So I can turn on the gas log fireplace,, and the fan to move the heat out, all from my Lazy Boy chair!) Just be careful and mindful that you do not draw more watts through the remote A/C unit then it is stated to be able to control... For the ultimate lazy, I just ran a water line from our reverse Osmosis water purifier line going to our refrigerator, (under the house), over to that same Lazy Boy easy chair. I installed a 2nd R/O water tap faucet ($17) on my oak TV tray table beside the chair, so now I can fill up my water glass while sitting in my chair, and not have to get up, go into the kitchen, to get a glass of water! (Now if I could just put that keg o beer, and install a 2nd tap on that oak TV tray, I would really be set, (and way too fat)... Just don't get too carried away, and turn your place into a James Bond Bachelor Pad!Comment
Originally posted by eco007Can you please tell, which company HEPA filter is best.
Another thing out there are ultraviolet lights to install just before the heater, just before the AprilAire, on that same return air duct to kill germs. The ultraviolet lights come on whenever the heater / fan motor comes on and kill's germs that can cause illness. I took mine a step further, and wired a wall switch into our hall closet, so I do not run the ultraviolet lights all the time, as they do burn out. I just turn the switch on when someone in the house gets ill. So when someone gets ill in the house, the ultraviolet switch is turned on, then the Aprilaire is put to be on either 24 hours a day, or 1/2 hour on, 1/2 hour off, to keep the germs down, and the air clean. It seems to help as with it on, we do not seem to share colds or illness nearly as often as before we had it, so IMHO it was worth the cost, which was not that much.
The heater we purchased came with a 10 year parts & labor warranty, so, hey, I expect them to replace that heater motor at least once in that period...Comment
If you have dust allergies a great solution is a central vacuum that exhausts to the outside.
I haven't seen a vac hepa filter that doesn't let some dust get byNABCEP certified Technical Sales Professional
Outside Exhaust
Originally posted by NaptownIf you have dust allergies a great solution is a central vacuum that exhausts
to the outside. I haven't seen a vac hepa filter that doesn't let some dust get by
the house. NO WAY said I, outside is a BIG ADVANTAGE to the central vac for us dust &
pollen sensitive types. Took me half a day to chisel a hole in the brick wall.
I have also had an electronic air cleaner for decades. I used to worry about the electricity
for running the blower often during non heat/cooling seasons, but no longer do since
generating my own power. Bruce RoeComment
very useful tips. thanksPerhaps when you have established yourself as a useful contributing member a link in your signature will be allowedComment
