Hello all,
I've been tasked to help with the design and construction of a large panel (1.58 x 0.8 m) solar simulator to evaluate (I-V curves, fill factor, efficiency, etc) solar panels that will be going in and out of use with our facility, however I have very little experience with this. I've used continuous xenon arc lamps in grad school on very small devices (1 cm x 1 cm), but I'd like to pursure the single long pulse (SLP, ~100 ms) method with xenon flashlamps since I believe that is how industry has been doing commercial testing to prevent excessive heating of the panels.
From my research so far there has been so many components involved in this type of equipment (types of flashlamps, power supply, housing, triggering, software, hardware/mounting, etc, not to mention being able to calibrate it to Class AAA?). Can anyone direct me to resources (books, journals, people, anything) that can offer insight into how I can possibly do this?
I've looked into just simply buying a system, however they are over my budget of $100k. Would it be possible to construct one from the ground up at that price that can perform similar tests?
Thank you for ANY help you guys can provide. It is greatly appreciated!
