World Record efficiency in Polycrystalline Solar Panel - 32.4%
  • sanbusel
    • 12
    We have achieved 32.4% efficiency on a Polycrystalline Silicon Panel - read "PANEL" - not cells. This is a world record for any kind of Solar Panel. This is also the maximum efficiency that can be achieved given the Shockley Queisser (SQ) Limit which speaks about 33%.
    How was this achieved?
    A special "natural" light sensitive electromagnetic coating was given to the panel, which enables maximum conversion of sunlight to power. This coating is organic and does not contain any chemicals. The process is simple. Just mix the powder in water and coat the solar panels or cells to achieve maximum efficiency.
    Sunblaze Solar Systems,
    Bangalore
    So the magic angel dust comes into play?
    Be a lot more impressive if a scientific organization supported the claims.
    • sanbusel
      • 12
      Thanks for moderating and letting better sense prevail!
      We are in the process of getting a UL Certificate for this efficiency record. Once done, we will republish under this post. It is not easy in a country like India with the limited resources that we have here to get things done. We are limited by everything. - except passion.
      • tomas90
        • Nov 2011
        • 7
        That numer sounds pretty impressive. As russ said. Real scientific prove will be your gamebreaker. At this point we will probably read at least a few news about it, but a forum post will do too
        • tandrews
          • Nov 2010
          • 111
          Organic is certainly a noble goal:
          Will watch this thread with wild flailing optimism.
            That is pure BS. UL certifies safety, not efficiency. UL does not publish or test efficiency of products.
              That pops up on the green sites every now and then when some blogger is trolling the university web sites where they are doing advanced work - maybe on the 25th of never it will show results.
              • sanbusel
                • 12
                Regarding UL Certificate, here is the discussion that has been going on:
                Dear Mr. Sulur,
                Greetings from UL !!
                Kindly provide your contact number to discuss on your below query.
                Thanks and Regards
                Shanthi T
                Sales Support Associate
                Underwriters Laboratories
                Kalyani Platina, 3rd Floor,Block I, No. 24, EPIP Zone, Phase II
                Whitefield, Bangalore - 560 066, INDIA
                T:: +91-80-41384400 Ext:: 64411 M:: +91-7760972026
                Sent: Sunday, January 15, 2012 1:26 PM
                To: Jain, Hitesh
                Cc: Saurabh, Sriparn
                Subject: RE: Need quotation for Solar Panel Testing & Certification *Lavanya Govardhanam
                Hitesh,
                I guess, only PVI measurement of 20W sample should serve their purpose
                • sanbusel
                  • 12
                  Regarding the Scientific Institution Test and Certificate, we are working with the premier Solar Institution in India and the mail chain is going on as follows. The testing will be completed in one or two weeks time. Then, we can all have a hearty laugh at how this was done in this same forum. Cheers everyone until then.
                  Dear Sir,
                  Thank you for contacting us.
                  I checked the website, but it couldn't find any information about the solution.
                  Can you share some information which will help us understand the product better?
                  Also what is the procedure of application?
                  Please share some application manual which will help us apply and
                  evaluate the product.
                  Thanking You,
                  Mehul.
                  On 1/13/12, Sulur Anbuselvan <sulur@sunblazesolar.com> wrote:
                  > Respected Sir,
                  > Many thanks for your reply. We have started the preparation of new
                  > sample and it should be ready by Friday.
                  > We will courier the sample to your address:
                  > Department of Energy Science & Engineering,
                  > Room No. 311A, Mechanical Engg. Indian Institute of Technology Bombay Powai,
                  > Mumbai 400 076, INDIA
                  > It should reach you by 23rd January.
                  > Once again, thanks for your valuable time and attention.
                  > Best Regards,
                  > Sulur Anbuselvan
                  > Bangalore.
                  > On 1/13/2012 4:38 PM, Chetan Singh Solanki wrote:
                  >> Dear Mr. Sulur,
                  >> Thank you for writing. We would definitely like to expolore your
                  >> coating. kindly do send us the sample.
                  >> regards,
                  >> chetan
                  >> On Fri, Jan 13, 2012 at 2:48 PM, Sulur Anbuselvan
                  >>> Respected Sir,
                  >>> Subject: Light Sensitive Electromagnetic Coating to increase Solar Cell
                  >>> Efficiency
                  >>> I am Sulur Anbuselvan, Research Scientist from Sunblaze Solar Systems,
                  >>> Bangalore. We have been working on an organic electromagnetic coating
                  >>> powder
                  >>> that can be applied on solar cells/panels to increase the efficiency. We
                  >>> tested from our end and observed that the efficiency of the solar
                  >>> cells/panels to increase.
                  >>> We would like to know if your esteemed organization would be interested
                  >>> to
                  >>> test our Light Sensitive Electromagnetic Coating Powder on your solar
                  >>> cells
                  >>> to observe if there is any improvement in efficiency.
                  >>> If interested, we would be most willing to send you the sample powder for
                  >>> testing. Expecting your positive reply in this regard.
                  >>> Best Regards,
                  >>> Sulur Anbuselvan
                  >>> Bangalore.
                  -- Mehul Raval, Doctorate Student/Senior Research Assistant, Solar Lab, Energy Science Engineering Department, Indian Institute of Technology Bombay, Powai, Mumbai-400076,India. Lab Contact: +91-25764887.
                  • sanbusel
                    • 12
                    Sample prepared and ready to be tested by National Centre for Photovoltaic Research and Education (NCPRE) at IIT Bombay. Fingers crossed. Will update the results by next week.
                    UL Testing/Certification plan dropped. Understood it is not worth pursuing by a Scientist.
                      Two totally different things - UL compliant is used for equipment or components - nothing to do with verifying claims such as yours.
                      Even if IIT Bombay say it is so you will have to go through other scientific organizations for replication of results.
                      As you don't seem to have engineers or scientists on your staff I am not expecting anything to come of it.
                      • solarpowered
                        • 21
                        I would say this is more of a hoax.
                        There isn't any break through's happening in India for atleast the next 25 years, the technology is that far behind, not to mention who would finance this?
                        The highest efficiency cell on the open market to date only achieves 22.9% conversion efficiency, "without glass". On a molecular level to have an additive claim that it can change the physical characteristics of a cell to convert more sunlight to electricity I find extremely hard to believe.
                        i believe one of the mods stated earlier "magical fairy dust".
                        Besides who boasts something that could be patented, every one would steal the rights to it.
                        • sanbusel
                          • 12
                          Dont write this one off yet...just wait for 2 more weeks for the results to be posted here.
                          India is the country that invented so many things before Christ was born. Have you heard about Aryabhatta, Bhaskara, Varahamihra, the great scientists of India in BC? Their genes are still intact in so many Indians. Thats why you see so many brilliant Indians worldwide in all fields of science.
                          We do not need funding to invent. We need only brains which we have in huge amounts.
                          • sanbusel
                            • 12
                            The magic dust can never be re-invented by anyone except us. So, dont worry about the patent part, lest stealing it.
                            • sanbusel
                              • 12
                              Once it is proved by IIT Bombay, we will start applying this magic dust on Solar Cells/Panels which will be made in India, the highest possible efficient solar panels that is ever to be made. We dont have plans to patent or license this to anyone. Yes, we came here to boast and we will keep boasting because we are capable of doing this.
