Please help me understand my production rate vs my system size.....???? Confused...
LOL ,
9.36 grid tied, Phoenix ArizonaComment
That would work for keeping the panels cool. But they won't produce any power in the shade. No mythbusters test neededPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
MSEE, PEComment
In Japan's larger cities, rooftop solar panels are stacked vertically to save space.Comment
That way I hope people will know I am joking and not being serious.Comment
This entire thread has ignored the conversion loss of DC watts to AC watts. It goes a long way to explain the OP's original question.Last edited by DanS26; 04-17-2018, 12:36 PM.Comment
I believe there was some discussions i had with my rep early on about the limit that Dominion Energy puts on residential installations before imposing fees/penalties. i believe he said as long as the system is below 10kW "DC", we're ok......we can generate 12,000 kwh 'AC" given my roof's position.
Did i get that remotely correct?
btw, how does that answer my original question? curious what you meant.Comment
There is a conversion loss, sometimes referred as inverter efficiency to convert DC watts as generated by your panels to AC watts that sent to the home or grid. Your POCO has nothing to do with this.
One of your panels outputs 305 DC watts under ideal conditions.....but your inverter only outputs say 290 watts AC. Your original question was mixing apples and oranges.Last edited by DanS26; 04-17-2018, 12:47 PM.Comment
Sorry I used an acronym.....in the electrical sense it only has one meaning:
I'm having a hard time understanding whether or not the "shading the panels during the daytime" comment was serious or a sarcastic response.
One thing I haven't seen covered (i skipped around a lot on this topic though) is pitch. Depending on where you live and the pitch in which you have the panels installed, that could also take away from your production, but being that you have a 7.6 kW inverter and you are sometimes seeing 8kW worth of production, then you are good.
Overall though, your location, and the pitch and azimuth of where the panels are installed all determine overall power production. They should have done a shade analysis as that would have shown you what the panels will produce throughout the year.
Again, if you have a 7.6 kW inverter, and they loaded it at about 130% of that with panels, your system is producing as should if you are seeing 7-8 kW peak production throughout the day.Comment
