Water cooled solar panels for significant output boost
  • bouncintigger
    • Jan 2015
    • 11
    Hi all. I know this has been done before, but I can't see any links to similar setups on this forum so figured you might be interested. I've set up an automatic water cooling system to improve my PV output on hot days. Take a look:
    Any comments or suggestions would be appreciated.
    Couple of issues of simple physics.
    1. The energy used to cool the panels is more than the extra power produced so you have net negative gain.
    2. I understand why you are using a water softener to prevent scale build up, but the trade off anyone that lives near a sea is salt water is hell on panels. You are trading Calcium and Magnesium for Sodium Chloride (salt).
    Unfortunately you are not the first to go down this road. Many have gone down this road before you and discovered the gain does not offset the energy used to run the pumps. That is why you don't see any systems for sale. Then you got the environmental whackos would eat you alive because you are wasting considerable amounts of water, especially in Perth where you have extremely low humidity means most of the water evaporates before you can collect it and recycle.
      Another point of simple physics affects those who want not only to cool their PV panels, but to make use of the heat removed from the panels at the same time.
      Sort of "Can I attach a solar thermal panel to the back of my PV panel and use it for heating?"
      The point is that for heating you want to get the thermal part of the panel as hot as possible, while you want that same fluid loop to cool the panel to the lowest practical temperature. For any application except pool heating, the two optimal temperatures are so far apart that any practical compromise will not in fact be practical.
      For pool heating, you have the problem of the corrosive effects of pool water, and I have still not heard from anyone who has made this application work.
      • Dink
        Dink commented
        Editing a comment
        Thanks for the info on Therma Hexx - I am unfamiliar with them but I will reasearch them now! For my situation, I already have a 13 year old solar pool heater that is starting to fail. This system is locatated on my only suitable southern oriented roof. I need to the keep the solar pool heater since the pool itself is mostly shaded by the house; however, I want to add photovoltolic system to cut back on my $600.00+/mo electric bills. Have you seen or heard of Therma Hexx installed on a pitched roof with photovoltolic sytem installed on top? ....after a quick scan of their website, I am not seeing it.
      • ncs55
        ncs55 commented
        Editing a comment
        Therma hexx are a newer product. I called them and asked about doing this. They have been working with a company overseas but have no data as of yet. It would be better to use your roof for PV rather than pool heating. You may be able to install enough PV to offset heating the pool. Although this is not the most optimal way.
      • Dink
        Dink commented
        Editing a comment
        Thanks, I just left them a similar question via their website. I am not opitimistic that a PV system (by itself) could make up for the solar pool heater. I live in FL and panels get REALLY hot and thus lose their efficiency. Since I don't have room to do both, I thought this type of solution would improve the PV efficiency while still heating my pool (though probably at a degraded level from a straight-up solor pool heater). These are my assumptions, not engineering calculations....though I have some experiance with each system independantly. I had an 18kw PV system at my last house and have the solar pool heater on my present home. Are you aware of any other companies other than FAFCO that have done this (married the PV to Solar hot water/pool)?
        Thanks again, I really appreciate your input!
    • bouncintigger
      • Jan 2015
      • 11
      Thanks for the feedback, but I have to disagree with you:
      1: A like for like comparison of hot day with and without cooling enabled, without any cloud cover whatsoever:
      32.8 kWh (12th January - 35°C max temperature) without cooling system running
      36.8 kWh (25th December - 32°C max temperature) with the cooling system running
      I use two 4L/min diaphragm pumps for this system, that have a maximum rated power of 31.2W each. The two temperature switches are ~ 1W each so you can ignore them. The pumps typically only run 50% of the time in the blistering sun and much less before 10am and after 2pm. Even if they were both running flat out, non stop for 12 hours in the day, they would only consume 0.75 kWh, but I've measured the load with a portable power meter and the typical daily consumption for the whole system is ~ 0.1 kWh.... negligible really.
      As for the water, you make a valid point that the water consumption is high. Currently I'm using ~ 500 mL/min net during the blistering hot part of the day. The vast majority of this though is not evaporative, but drift loss wasting going onto the tiles. I expect I'll be able to at least halve this consumption with some tweaks to the setup. Even if we assume 500 mL/min over 6 hours, this is only 120 L/day or ~ 15c. As I said, I expect to be able to get this down by half with some tweaks to the setup. When comparing this against the 4 kWh gain in PV output, the cost of the water is trivial (although yes yes... water is precious).
      Regarding the water filter, you're mistaken about the chloride and how the filter works. The resin is a cation exchange resin and doesn't load chloride at all. The regeneration process in NaCl or HCl only exchanges Mg2+ and Ca2+ with either Na+ or H+. The chloride remains in the backwashing tank. Provided the filter is suitably flushed prior to using the water on the roof again, there won't be any more chloride in the water than there is in the scheme supply (my house is ~ 200 ppm from a Mohr titration test). The only ions you'll get on your roof if you run the filter correctly, are Na+ (or H+), and sulphate / carbonate / bicarbonate. In the case of H+ regeneration, we're only talking ~ 150 ppm, and there's more than enough basic carbonate to neutralise the acidity. The water will be exceptionally pure and you'll have no chloride corrosion troubles.
      If I've missed something, please put me straight, but as far as I can tell, the number stack up....
      Thanks for the input though I really do want to know if there's a fundamental blunder I've made so please don't let this post dissuade you from trying to convince me further!
      • bouncintigger
        • Jan 2015
        • 11
        One more thing. You actually want evaporation rather than collection and recycle. The perfect system would not have any water collected and recycled, with all of it evaporating. The latent heat of evaporation far exceeds the heat capacity of the water. Dry air is better than humid air at any given temperature.
          • 15014
          Have fun with this system, but I'm of the opinion you're not gaining much, if anything in terms of a net increase in overall efficiency - As Sunking already noted, more than likely the parasitic energy far outweighs any increased panel efficiency from any lower panel temps achieved.
          There are a lot of environmental variables that affect system output. Maybe a fundamental blunder: While I believe your numbers, I'd wager a guess you do not have sufficient instrumentation to justify or explain the diff. in output you describe. Maybe the 25th was windier and/or from a diff. direction for example. Or, perhaps the ambient temp. profiles as f(time) were different. I can get 5% diff. in output on consecutive seemingly very close, cloudless insolation days on what seems to be wind vector diff. alone. Also, know that what your eye may be telling you are identically "sunny" days may, and commonly do have insolation levels that are different by a couple % or more.
          Also, no way to tell, but as a 1st approx., depending on wind, dew point and a few other things, probably something like half any additional cooling that is achieved by your scheme is probably achieved is through evaporation.
          FWIW, I'd put the reservoir on a scale and keep track of the tare weight.
          • bouncintigger
            • Jan 2015
            • 11
            I have more data than I know what to do with, and believe me it all points to massive power gains when the cooling system is on. Here's what happens when I pulse the system on / off in short intervals:
            You're missing the point. Evaporation is the aim of the system, not a problem to overcome! The biggest problem is losing water onto the tiles. The latent heat of evaporation required to balance the steady state sensible heat we're trying to remove amounts to a relatively small amount of water. I have tracked my water consumption (at the Watercorp meter... scales on the tank obviously won't work as it's always kept full with the supply float valve) and as I said, it's ~ 500 mL/min when the ambient temperature is ~ 35°C. Most of the time, the net water use is much less than that.
              • 15014
              Enjoy your learning experience. Good luck.
              • DanS26
                • Dec 2011
                • 987
                Commercial company already gone down this path....although in a little different manner.....
                  Analyze BS and you get more BS. The gains are vaporware
                    [ATTACH=CONFIG]5744[/ATTACH]
                    These data would be more compelling if the time that the water was turned on and off was overlaid on the chart. The idea that "massive" power gains are available is misleading... the temperature coefficient of the panels is published on most data sheets, and is something around -0.43% / deg C for many panels currently in production. A (substantial) 10 deg C reduction in panel temperature would be expected to result in an improvement of a 4.3% in power.
                    The method of cooling used here is hard to understand. By running liquid water over top of the panels, some amount of sunlight will be reflected or adsorbed by the water, reducing the transmitted irradiance. I would guess that there is some phase shift in the pulsed data shown here, where the "peak" shown occurs after the water has turned off, letting the full solar irradiance hit the panel, but generating higher power from the cooler panels. The magnitude of the peak may be bigger than what would be predicted from panel temperature coefficient alone because of the fact that the power in the "trough" of the pulse may be artificially depressed by the blocking effects of the liquid water.
                    A more effective way to cool the panels, I think, would be to mist them from the back side. Let nothing come between the sun and the panel, and by misting, it will push the cooling mode more towards evaporation than conduction. With a pan underneath, any excess liquid water could still be collected and reused. I am still doubtful that even that improved cooling scheme would be a net benefit.
                    • ncs55
                      ncs55 commented
                      Editing a comment
                      I would disagree with that statement. I have experimented with this principle during maintenance and module cleanings. Water does not block irradiance, it amplifies it, actually the water would act more like a million little fresnel lenses in its effect on the module. I watch production variances during regular cleanings. In a few experiments we have just misted the modules to see what happens and the production spikes upward until the mist evaporates. Now when I say mist, this is not enough to cool a module down I am referring to a light mist on a full sunny day. We have tried this before and after cleaning and seen the same result. I would agree with the OP. And also with the others about water usage. but a once a year cleaning of an array could very well use more water than a system like this, that may also help the modules to stay clean in the process. I would say this data looks promising.
                  • FishGun
                    • Jan 2015
                    • 25
                    Slick. Thanks for sharing. I think the on-off graph is more of a seller than the 2 diff days overlayed.
                    About 10% gain...so prob a 20-25deg reduction...seems reasonable. It pretty much always comes down to cost to purch/install/run/maintain. If you can do it for less than the cost of 5-15% increased output than it's a winner. If not, it's still fun to mess with!
                    I've seen about 15% increase in output washing/spraying my panels in midsummer. Also have seen the highest output of the year in March...suns at pretty good angle and temps are cold, but some of the gains are from the sun reflecting off of snow too.
                    I've been toying with something similar for my array as well...or at least trying to figure a way to cool cheaply. Alum fins, alum duct, alum fins with circulating fluid, misting the back of panel, dripping the back panel? Can't decide which to do. Or if any.
                      20-25 deg C? Really? If the system is operating at 35 deg C as the poster suggested, that would require cooling to 10-15 deg C, or 50-60 deg F. That is not going to happen with the method proposed.
                      • Ian S
                        • 1879
                        I believe the O.P. is talking ambient temperature of 35C not panel temperature. Panel temperature can easily run 20 C deg higher under full mid day sun and calm wind conditions.
                          Fair enough, but water used in this way will never pull the temp down by 20 deg C. Here is an example of a misting system using a whole lot more water that achieved 2 deg of cooling. Any water that recirculates will rise in temperature without an additional heat exchanger to cool it back down, further defeating the cooling power of the system.
