Help me understand my system
    Originally posted by FIDIRO
    This is a sunpower equinox system with E20 Series 327 watt solar panels. System was installed summer 2020 zip code 08882 and don't have any info on which inverters, I would have to give them a call to try and get that information or climb up to the 2nd story roof to try and peek under panel. I'm going to say it is enphase but would need to confirm.
    If I have seen 8.5kw then the inverters will likely be capable of running the panels at 327 if they are all working properly, but being that during the summer heat I was only seeing 7.3 on bright sunny days then either some panels are not producing or they drop that much because of heat.
    If the summer heat did cause the drop then I should be seeing 8.5kw on good sunny days now that the heat has settled down. I don't have access to individual panel and hoping that is something that will come soon.
    It's likely your inverters are rated for less than 327 W output.
    I don't doubbt your seen instantaneous array outputs of or a bit more than 8.5 kW. As for system output >= 8.5 kW, I have the same panels as you have. Only difference is they're 8 yrs. old (but going strong).
    I too have seen momentary or very short term input to my string inverter > the 5.28 kW STC raing of the 16 panels, but always less than for a couple of minutes, always in the spring, always within about an hr. or so +/- on either side of the time of min. incidence angle on my 5.2 STC kW array and always when it's a partly cloudy with reflections from clouds acting as cloud cloud based albedo enhancement.
    The best array input to my inverter I've ever recorded from my 16 ea. Sunpower 327's on a cloudless day is 4,972 W. That was on an unusually cold, very windy day in May with a near zero solar incidence angle on the array with the average array temp. was only about 12-14 C. above the ambient air temp. on my roof.
    Read the book when you get it. There are things about arrays and how they work that you don't know (yet).
