Trace Engineering (Xantrex) Power Conversion-Solar Inverter. 4000Watts. This unit is very good quality, great cosmetic shape and runs great. I had it disconnected professionally and checked by a certified electrician, so it was working well. It is typically used for off-grid setups, and was using 8 75 Watt solar panels to charge backup batteries and run some of the house power. It can do a lot, the technical specifics are beyond me. Have the DC Disconnect unit also, and the Trace C 40 charge controller, steel back mounting plate, Trace T-220 Transformer, and a Delta Lightning Arrestor. All included with the inverter. Also 8 Solarex MSX-77 Panels
Looking to find a home for these.
