the cost of Solar power system
  • brother-one
    • Apr 2016
    Dear everyone, I would like to ask you please about the equipment prices of making slower system.
    Panels: SILLIA 320 W. POLY ?
    Battery: GNB opzV,1957 Ah ?
    String Box: PN-GCBB- 8 Strings, 80A, 275 VDC, IP66 ?
    Charge Controller: STUDER charge controller VT-80 ?
    Inverter: Studer XTH 6000-48-6Kw?
    Monitoring System: Remote controller Studer RCC-02, Communication Set Studer Xcom-LAN, Temperature Sensor Studer BTS-01?
    Main Battery Switch: With Circuit Breaker ?
    Other Electronic Components: MC4 Connector for Panels male and female?
    Earthing complete Kit 25m?
    Individually Designed System installation Kit?
    Control Cabinet Studer X-connect?
    Earthing Cable Kit with Ring Terminals?
    PVC Cable Conduit ?
    Aluminum Profile Bar Kit for Inverter Mounting?
    Changeover Switch Moeller 63A?
    Battery Rack Kunstmann?
    AC Circuit Breaker?
    Pease if someone what are the prices of these equipment ?
    Slower system is not even the word for it, a perfect recipe how-to destroy a very expensive battery not made to do what you want. Perhaps I misunderstood but Assuming a 48 volt battery, (48 volt is foolish at 1957 AH, 12 and 24 is just plain ignorant and dangerous), you would need a 9600 watt panel and three of your controllers. If you daily cycle those $18,000 batteries will be worthless in 1 year.
    FWIW no battery system should ever be greater than 800 AH. Otherwise you are doing something terrible wrong or not a solar off-grid application.
