Hi
I am working on hdf files related to solar radiation and there are lot of parameters in that. Some are related to solar panels and some are not. I just want to know if i have selected the right parameters. Following are the parameters:
EMIS = Surface emissivity
TS = Surface temperature, ALBEDO = Surface albedo, ALBNIRDF = Diffuse beam NIR surface albedo
ALBNIRDR = Direct beam NIR surface albedo, ALBVISDF = Diffuse beam VIS-UV surface albedo, ALBVISDR = Direct beam VIS-UV surface albedo
LWGEM = Emitted longwave at the surface, LWGAB = Absorbed longwave at the surface, LWGABCLR = Absorbed longwave at the surface with no clouds
LWGABCLRCLN = Absorbed longwave at the surface with no clouds or aerosol, LWGNT = Net downward longwave flux at the surface
LWGNTCLR = Net downward longwave flux for cloud-free sky, LWGNTCLRCLN = Net downward longwave flux at the surface for clear sky
LWTUP = Upward longwave flux at top of atmosphere (TOA), LWTUPCLR = Upward longwave flux at TOA assuming clear sky
LWTUPCLRCLN = Upward longwave flux at TOA assuming clear clean sky, SWTDN = TOA incident shortwave flux
SWGDN = Surface incident shortwave flux, SWGDNCLR = Surface incident shortwave flux assuming clear sky
SWGNT = Surface net downward shortwave flux, SWGNTCLR = Surface net downward shortwave flux assuming clear sky
SWGNTCLN = Surface net downward shortwave flux assuming clean sky
SWGNTCLRCLN = Surface net downward shortwave flux assuming clear clean sky, SWTNT = TOA net downward shortwave flux
SWTNTCLR = TOA net downward shortwave flux assuming clear sky, SWTNTCLN = TOA net downward shortwave flux assuming clean sky
SWTNTCLRCLN = TOA net downward shortwave flux assuming clear clean sky
TAUHGH = Optical thickness of high clouds, TAULOW = Optical thickness of low clouds, TAUMID = Optical thickness of mid-level clouds
TAUTOT = Optical thickness of all clouds, CLDHGH = High-level (above 400 hPa) cloud fraction
CLDLOW = Mid-level (700-400 hPa) cloud fraction
CLDMID = Low-level (1000-700 hPa) cloud fraction
CLDTOT = Total cloud fraction
FOLLOWING ARE THE SELECTED ONES: I think these parameters affect the solar panels.
Please help me in selecting the right parameters that affect the solar panels.
