To connect the panels thu the attic it would be a lot easier to use than copper.
Someone said that pex can't take the high temps.
It depends on the design temperature and pressure of the system as well as the worst possible case.
Pex tubing is chemically stable well past 180F, but may not be rated to withstand its full design pressure at higher temperatures. In particular, even when the tubing itself can withstand its rated pressure at higher temperatures, the combination of thermal expansion and material flow resistance may keep fittings, particularly slip-on fittings, from withstanding that same pressure.
If your panels can produce a stagnation temperature of 212F (or even higher temperatures because of pressurization and coolant composition), you can expect PEX to fail. If you have high stagnation temperatures but an open (zero pressure) system, it might survive, but why risk it.
On a drain back system with flat plate collectors it's OK to use if you connect at least 15 ft of copper piping to the collector inlet and outlet.
Do not use on a pressurized evacuated tube system
What are temperature limitations for PEX? PEX tubing can be used up to 200° Fahrenheit for heating applications. For plumbing, PEX is limited to 180° F at 100 psi. Temperature limitations are always noted on the print line of the PEX tubing. PEX systems are tested to and can be used with standard T and P relief valves that operate at 210” F and 150 psi.
Even CPVC is not specified for panel stagnation temperatures.
CPVC systems conforming to ASTM D2846 are rated for continuous service at 100 psi and 180 degrees F and are marked accordingly. The model codes recognize CPVC's capability to handle short-term pressure/temperature excursions beyond these levels.
