Yes - a Redrock kit as I remember
receiver for parabolic dish solar concentrator
I am new here and want to see these pic's. name is Logan
Hello,
with my students, we are building a solar tracker using a 180cm parabolic dish
(pretty much like this one: http://www.heliotrack.com/Dish180.html ).
We have the tracking almost under control but my question here is about the
receiver which should be placed at the focus of the parabola. The heat fluid should
go through "spiraling" pipes in the receiver, get heated and then go back to the water
tank in the house.
Does anyone know where to buy such a receiver (even second hand)? if not, can anyone
help us on how to build it (material, dimension, etc).
thanks,
NicComment
What is your working fluid ?
An aluminum block, 24" square, with a grid network of holes and manifolds drilled through it, and the blank ends "plugged" with threaded plugs, will collect and transfer a lot of heat for you. After it's machined, the outer surface is anodized black, to absorb energy better. As long as you keep pumping fluid through it, it's pretty safe, but if you overheat it, you will destroy it.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
As for the manifold, we'll have to build one made-to-measure, because of the large distance between tubes (around 60 cm). The manifold for solar panels with vacuum tubes have a much shorter distance between the tubes (in the picture attached, the manifold is shown as the bottom figure). As you can see, the copper header will be insulated to reduce heat losses in the manifold.
figure_manifold.jpgComment
The working fluid we plan to use is Tyfocor LS. It's an antifreeze fluid, the same fluid than the one used in "classical" solar panels with vacuum tubes. It has nice properties (anti-corosion, resistance to heat).
[ATTACH=CONFIG]2624[/ATTACH]NABCEP certified Technical Sales Professional
for our trough project, yes. It is very similar to http://georgesworkshop.blogspot.ca/2...-20-intro.htmlComment
hard to believe there is no difference in the winter, since vacuum tubes really reduce the heat losses (especially critical in the winter).
Now, maybe you mean the difference between fixed flat panels (with vacuum tubes) vs tracking concentrating troughs (with vacuum tubes) ?
Georges has done interesting tests (concentrator vs flat panels), although both with vacuum tubes and with tracking, so it might not
be relevant to what you had in mind.
Some commercial parabolic concentrators do use a vacuum tube rather than like George's - a different thing altogether.[SIGPIC][/SIGPIC]Comment
Georges did two different versions of his parabolic trough concentrator: the old one (about 2 years ago) with a simple non insulated tube, and more recently, I believe last summer, he did one with a vacuum tube. (see the links in my previous message).Comment
Ok - I will look at that - hadn't seen it![SIGPIC][/SIGPIC]Comment
Now is the time when the survivors report about the experiment! Both our school projects have ended
with some interesting results, but the concentrators are not fully complete. There are still some things
I'll have to improve and finish, but let's say a good prototype (for both projects) was built.
You can read both reports my students wrote on my webpage:
under the section "Diploma done during 2012". Since we live in the
Italian speaking part of Switzerland, the reports are in Italian, but
one can look at the pics and graphics...
In particular,
parabolic dish concentrato:
videos:
As I said, I will go one working on both projects, maybe with other
students and I will report on this forum.Comment
