This is what I have Splash RV & Marine Antifreeze
Looks like the concentrations are a bit different Between the Harvey heat / Splash / Sierra
Harvey heat from plumbing supply has
Dipotassium Phosphate 1.0 -2.0%
Propylene Glycol 65.0 - 70.0
Slash RV stuff has
Propylene Glycol <9 percent
Glycerin <16 percent
Sierra has
Propylene Glycol 94-96 %
Water 3 %
Proprietary Additives 1-3 %
Slash data sheet has this as well.
APPEARANCE: Clear pink liquid
BOILING POINT: 370°F
ODOR: None
FREEZE POINT: 9°F
pH: 8.2
VAPOR PRESSURE (mm of Hg) <.01 @20C (68F)
SPECIFIC GRAVITY: (water =1): 1.01
VAPOR DENSITY (Air =1): 2.6
SOLUBILITY IN WATER: 100%
EVAPORATION RATE (BuAc=1): Slight
Slash RV stuff has
Sierra has
Water 3 %
ODOR: None
FREEZE POINT: 9°F
pH: 8.2
