Hi, I have vacuum tube solar water heating on my house in Spain, and it works great !!
in fact I was so impressed that I now import and sell them here.
I have found the best type for the hot climate combined with poor water quality to be the indirect pre heat type.
The main reasons are.
1 vacuum tubes will provide hot water nearly all year round
2 lower cost than split systems
3 can provide hot water at mains pressure, not gravity feed
4 main tank is vented so if the system over heats, steam and boiling water can escape
5 in kit form for easy assembly at point of use
6 water in tubes provides extra capacity
7 dose not rely on a pressure relive valve to protect the main tank, which can fail due to poor water quality calcium build ups
8 dose not require a boost pump for pressure, as is normally required on a non pressure gravity feed unit
Dose any body use this type of swh in their area, or what is your preferred type and why ?
Tony cssolar
Tony cssolar
