So I'm slowly restoring a closed loop solar thermal system that I was given for the effort of de-installing. When taking the system down, the loop was already completely dry. Later, I found a few pinholes in the manifold of one of the collectors. The Wilo pump was also seized, with a bunch of solidified gunk in the back housing that appears to have built up and warped the cartridge. I'm just guessing that this happened to the pump after it continued to run without actually moving any fluid (having lost pressure in the loop due to the pinholes).
If this assumption is accurate, then one would think that a pressure switch in the loop (that would turn off the pump if pressure was lost) would be a normal practice. However, in all of my research on these systems over the last few months, I haven't come across any mention of anyone doing this and I also haven't been able to find a switch for this purpose marketed for solar thermal.
So if no one is doing this, then there must be a reason it is not needed. Perhaps my guess on what happened to the pump is wrong. Any thoughts?
