Hiya
Have a solar tube array on the roof.
Closed system with glycol, heats up the water tank through a heat exchanger.
Tank feeds into the main boiler on demand
Suntana 2 controller.
The pump is working, warm itself, and the controller turns it on and off based on tank/collector temp difference. Pressure is up to about 4bar (which I think is water pressure)
The tank sensors are showing a constant 17-19 degrees although the collector sensor is up to 90 degrees at the moment (very sunny for the UK) and their pipes are cold.
A few weeks ago, I noticed that the tank sensor cable was broken and that the controller was showing an interruption. I resoldered it and all was good but then noticed that water isn't getting hot. The collector isn't overhearting or blowing out and there are no puddles of glycol on the roof (it did this when we moved in as the fluid hadn't been changed in years).
I changed the sensors anyway - no change.
I know nothin about these things, there are various valves and taps in the cupboard and I have no chance of getting someone out during the lockdown period and am worried about the thing overheating.
Would a picture help ?
Thanks for any help
worried of herefordshire
Thanks for any help
