I can't see any other valves apart from the one one the roof (which I don't have access to) and the one between the fill points. I know the one between the fill points opens because I can pump fluid from one port to the other if I open it.
I didn't need to drain the system in order to install the valves because that bit of pipe work didn't have fluid in it. I did start to drain down when I thought the pump might be jammed and got some clear orange fluid out which looks pretty much like the Fernox S1 I am trying to top up with.
