Open vented solar system
  • tom ashaig
    • Jul 2019
    Hello, I've just joined. Fairly green in all senses of the word. Just out of curiosity, and meanness, I'd like to make a DIY solar hot water system that is open vented, and works very like an old fashioned back boiler in an open fire, i.e relying on thermo-syphoning. Difference being I would use the hot water tank (1) ,full of water and glycol, as a thermal store, with the panels (radiators) below the tank. This tank would be fed from an open vented fill and expansion tank. The water from the main (open) cold water tank to the showers would go through the coil of Tank 1 and , pre-warmed, into tank 2, which has an electric immersion heater. This tank also is open vented with a separate fill and expansion tank. Intending to use 22mm copper from radiator to tank 1, and from tank 1 to tank 2, and 28mm copper to vent both tanks over both fill and expansion tanks, which will be galvanised steel.
    I realise this will not be very efficient, but I have a supply of old radiators and old tanks, it will cost very little, and I figure any solar heating of the water is better than nothing. Question is, will it be safe or not, and if not, is there anyway I can make it safe without a pump?
    Thanks
    • 15005
    See builditsolar.com for some things to consider and also some things not to do. Lots of redneck engineering but a few nuggets of genius as well.
    • tom ashaig
      • Jul 2019
      Many many thanks, just the sort of lead I'd been hoping for.
        • 15005
        You're most welcome. Just don't take any of it too seriously. Well intentioned ignorance can be dangerous, or at least wasteful, especially when it meets social media.
