Currently/original house is a lot home, heated/cooled by a Fujitsu 36K mini-split.
Basement (900 sq feet) was built with radiant floors in mind (5 pex loops). Basement insulated with Superior Xi walls (estimated to be R9, see link below)
New addition was built, including basement. Basement floor was also prepared for radiant heating (9 pex loops.. about 800sq feet)
Not sure why loop count is different, no good answer there.
New basement outside block is 12", mostly filled with concrete (it holds a heavy garage on top).
Both floors have some insulation at bottom (estimating 1")
I have all the totals on how much concrete was used, as I have receipts
I also have some flat plate solar panels (7 units of 3x5)
The new space is bare block walls, only painted inside outside for water protection.
The idea was to take advantage of thermal mass..
House does have a 10k Solar array facing south. It's working out rather well (only have bills nov-mar, averaging below 150$.. not heating new space yet)
I am a little efficiency obsessed, but also want to have a system have a reasonable payoff
Initially I thought of getting a wood boiler.. but it seems very expensive and overkill for my application.
Now I am leaning towards drainkback solar with Backup (for simplicity, maintainability, and being DIY friendly), with backup being a super efficient (4-5COP) Sanden water heater
Discounting the fact that this setup may not be 100% supported by the manufacturer.
What's my path to figure out what I really need?
E.g. how do I calculate taking advantage of heat mass.. how do I determine what R value I will need to add to all walls.. how do I determine what storage outside of concrete I need (e.g. solar tank), how do I determine that what I am thinking is a good option.
Thanks,
R9 reference.
Thanks,
R9 reference.
