I've been wanting to set up a solar system to assist heating my garage. I'm in a typical ranch house with the garage under the bedrooms. I currently heat with a hot water Modine unit. I'd like to install a piece of cast iron on the wall and set up a closed loop.
The garage is about 800sq ft.
I've read here that people don't recommend water systems if the climate freezes. I don't understand that. First, my neighbor has had a system running for 40 years and he makes more hot water than he can use. Second, I figure I'll use non-toxic anti-freeze or similar.
Is this feasible?
Should I build or buy?
What size box/unit?
Do I need a pump?
What do I do in the summer?
TomJV
Is this feasible?
What size box/unit?
Do I need a pump?
TomJV
