As you all know, I have not been here long. I do want to ultimately do solar but my state discontinued its tax break. I will wait and save until it comes back if it does. It was pretty big. So, in the meantime, I have been trying to seal up my envelope of my home as best I can and by using ideas on this site as well as google. I wanted to do the blower door test but there is no one close to me and they wanted to surcharge me for the drive so instead I opted for the free one from duke power.
So, even before duke gets here, I took it upon myself. My house is brick, 2100 sq ft, large great room in the center and a full unfinished basement and 9 foot ceilings.It is tough to heat. Its also 39 years old with original windows. So here are some of the things I have done so take these down and if you want , I certainly recommend you give it a shot.
Some of these were done up to a year ago but most were done in this year so far. Can you tell I was tired of freezing and pay high power? lol
Last Year
Installed new Trane XR15 3.5 ton outdoor unit and new Trane indoor unit
R-30 cellulose in the attic
2017
Foam Wrapped the cold and hot water lines in the basement.
Foam wrapped and taped water heater lines
Insulated trunk of unit and cold air return
insulated water heater.
Foil taped all seams in the register lines
Sealed where register meet the floor
Insulated all large holes in basement ceiling (large pipe holes, shower drains etc.)
Put new door sweeps on basement double doors
New Foam on basement double doors
Found that the only 2 basement windows we have were partially open on top and bottom
New Foam around main door entrance
Rubber insulation around window slide tracks
covered up doggie door (she died)
sealed off fireplace
sheet metal over chimney caps and siliconed them shut
Replaced every bulb in the house with LED
Installed smart power strips in every room with phantom appliances
Put all DVR's on timers to only run 8am until Midnite then shut off completely from midnight to 8am
Put timers on both freezers to hold at 0 degrees instead of the lowest setting of minus 5
Cleaned the coils on the refrigerator with shop vac and scrub brush
Put in a new trane smart Thermostat
Insulated every light switch and outlet with insulated pads
Hand Washed dishes all but 2 days in Feb ( I had the flu so screw it, we let the dishwasher do it)
Most importantly, had a family meeting about being intentional with not only our money but our resources. Making a smaller footprint on Mother Earth and keeping more money in our pockets at bill time. This went VERY well. There are THREE teenagers and my wife in my house and though, I never said anything before, some days, I would count 7 or 8 showers between us all. They have really taken control and by doing this, I think it will carryover to their homes and lives. We are also on a tight budget and the kids are very aware of this as well and it shows when they go shopping. Overall and I am very proud of them so far. Plus our water usage dropped from a 5500 gallon average to a 3500 gallon average. Water bill went from $60 to $45
Did I spent alot of money? Yes. Where some of these useless? Probably. Does it matter? No to me because I wanted to do it and it got done. Was February a mild month? yes. It was also short. I do take this into consideration.
For the last 3 years (as far as Duke Energy will let me go back). I have averaged 1800 kw/h per month usage averaging $200 or more per month ( I know, I am ashamed, we are hogs but not anymore) with the largest month being 2400 kw/h. We have never been under 1000 kw/h but once in 2013 when I was wood burning it was 1100.
Feb 2017 was 1148kw/h and our bill was $108. With all that time and money spent, I still feel like the heavy weight champion of the world.
Thanks again to ALL that contributed ideas and thoughts. ITS NOT OVER tho! still plenty of more to do. I do want to mastic the ducts and seal off a little more things here and there and when my 20 year old electric water heaters dies, go with a heat pump water heater as well as the 20 year old fridge even tho it takes nothing hardly to run
Thanks again guys!
Last Year
2017
Thanks again guys!
