Hi,
I have a question or 4 about my 6 year old Shuco system and I've been abandoned by my installer.
I've been seeing inaccurate readings from the in-panel sensor (a thermistor) that are telling the controller it's not warm enough to do anything. I know it's wrong because I can easily monitor the actual temperature of the glycol. For example, today the fluid temp was pushing 120F while this sensor was only reading around 50, although it would cycle from a low in the mid 40's, slowly warm up to around the low 60's, turn on the pump and slowly drop down again. Outside temps were in the 20's.
The sensor is mounted in a rubber grommet set into the side of the panel frame, upper corner.
My first thought was to push the wire into the grommet deeper thinking there was too much exposure to the ambient. That didn't seem to do much to the reading at the controller.
Then I pulled the wire and grommet out to actually see what was what. It was what I expected, a chrome metal looking tip which I then thought might actually be touching framework inside the panel, so I pulled it back a bit so the tip would not be contacting anything but air (inside the frame). This also didn't seem to change much but I started to lose sun anyway, so here I am with my humble question(s):
Am I right that the sensor tip should be suspended in air inside the frame (seems like a no-brainer)? If that's the case I'm concerned about exposure on the outside of the grommet and the wire itself to the elements. Would that conduct cold to the sensor and throw it off and should it be insulated?
Also, can these sensors go bad and I'm seeing a dying one?
And a separate question: can I handle checking and adding glycol if needed? It hasn't been serviced in a couple years. I have the service manuals which discuss it but they make it out to be something requiring expensive equipment and a minimum 2 year degree.
Thanks in advance.
Schuco Solar Station PS 1.3
Schuco "Advance" Collectors CTE 215 CH (x3)
Schuco SDC 204 system control unit
Thanks in advance.
