What's the proper procedure for bleeding air out of the solar panels after the flushing the water heater?
We live in an area that never freezes. Our solar water heater system sends potable water from the 80 gallon electric heater up to two solar panels on the roof and back down to the water heater using a small temperature difference controlled pump. The system has been installed for about 2 years and I want to flush the water heater by draining it completely and then pulsing the cold water inlet, drain, repeat until clear.
Our two solar panels are hooked up as follows:
Heater>--->Circulation pump>--->Ball valve>--->hose bib>----/roof/--->T fitting>---> TO BOTTOM OF EACH SOLAR PANEL == FROM TOP OF EACH SOLAR PANEL>--->T fitting>---/roof/--->Hose bib>--->Ball valve>--->Heater
NOTES:
- Cold water from heater goes up through the roof where there is a "T" fitting on the roof and the two outlets feed the bottom "left" of the two solar panels.
- There are hot water outlets at the top "right" of each solar panel and they both feed a "T" fitting with the common outlet going down to the heater.
- There is only one pressure relief valve at the top "left" of one solar panel.
So again, what's the proper procedure for bleeding air out of the solar panels after flushing the water heater is complete?
NOTES:
