We will be heating about 2200sqft at 6000' elv in northern NM. The house is passively designed and will have radiant floor heating. I do have some experience with a 2 panel 1 tank system I had in NM and it was adequate for hot water and a bit of radiator heat for the bathrooms, but that was about it in the wintertime. Had gas furnace as primary heat, as well as a gas HWH for backup. Solar preheated this.
Though I plan to get some professional input, I do want to have an efficient and cost effective system in mind. Now I want to use a 4 panel system with 2large solar storage tanks (thinking 120gal) in parallel. Both the solar and the radiant floor will be glycol based and isolated via heat exchanger.
My dilemma is the back up heat source and its configuration . Of course I am hoping the passive and the solar panels will be enough, but one must plan for those long cloudy weeks.
Would it be effective to use a condensing boiler such as a Munchkin or Peerless as back-up/booster heat, Polaris with additional storage (expensive), or just use storage tanks with either gas or electric elements? Gas is preferable.
On configuration, if I go with a boiler is it better to put it in line and act as a booster for hot water demand, or as an indirect heater for the storage tanks?
I can find all the configurations, but no mention on efficiency or effectiveness.
Bill
Bill
