I had a glycol system stagnate for a while this winter before I noticed. Got an air bubble in the system and the little El-Sid pump couldn't overcome the airlock. Once stagnated, any decent solar panel will boil water. Once boiling, the T&P valve blows, and then I have a bigger air bubble. Expensive mistake! The first lost glycol went on my roof and was lost, once I realized that I ran the T&P valve into a 5 gallon bucket through a hole in the lid. Just went up to check and I've caught about 3 gallons. At least I didn't lose it, but there is more reoutble in the system because of this.
If I ever get the system stable, and all the air out, and keep my pump going when it is sunny, this won't be a problem. Do other folks end up running the T&P to a bucket just in case? What is common practice?
