Any self educated opinion very appreciated here, don't need exact engineering analysis by a long shot.
I'm running 2 each Grumman 3' X 7' glazed solar HW panels with copper collector tubes thermosyphon into a 55 gallon HW tank in a box with about 8" of fiberglass around it. Panels are at ground level and 45 degrees, the tank is on about a 4' pedestal. Not quite high enough but it thermosyphons just fine. Worked 3 years, can get up to 160 degrees in tank in summer, perfect for direct feed to dishwasher with heating element disconnected in this off grid mountain cabin. (5000'+ altitude East of Mt. San Gorgonio, on way to Yucca Vy, California.)
I put in a home built auto drain out system to prevent freeze damage. Servo valves cut off lines to/from tank, a drain valve opens, vacuum breakers open above collector and water in collector, looks like 1 1/2 to 2 quarts, drains onto ground on freezing nights. Worked fine until it failed and burst copper lines in collectors as expected. Damage can be fixed again but what a PITA!
Now I want to convert to a glycol loop through collectors and use a heat exchanger at the tank top. Question is, WHICH heat exchanger?
I'm looking at the small 10, 12 and 20 plate units on ebay like item #250963082494, and like the vendor pextubing sells on ebay as for example item #390667900898. These exchangers all look the same and are no doubt Chinese made. The 3/4" fittings match the 3/4" copper I'm running to the collectors so that seems OK..
Will a 10 or 12 or 20 plate one of these small units work for me do you think? All considered opinions greatly appreciated!
Todd F.
Todd F.
