Installed a solar drainback system to heat hot water. System consists of 3 4x8 flat panels set at 52 degrees latitude (I am at 42 degrees latitude) due south. Piped to a 12 gallon converted electric hot water heater used as the drainback tank. I have fitted this tank with a sight glass to see the level of water in the drainback tank when operating. This feeds the bottom coil of an HTC 120 gallon dual heat exchanger hot water tank. This is fed to a Taco model 9 electric pump designed to pump over 36 feet of "head". A Caleffi Solar model iSolar4 controller set to drainback mode is the brains.
Problem: I have the tank max shutoff set for 160. The iSolar4 unit automatically sets the panel shutdown temp to 200 when in "drainback mode". I recently came home to find the unit shut down due to excessive panel temperature. ( This is done because distilled water is used as the heat transfer fluid and will boil at 210. ) So the assumption is made that the panel temp reached 200 and the controller shut it down. A blinking code on the panel of the controller tells me so. Checking the current temp of the panels at 180, I reset the system and it promptly restarted. Here is the problem: The pump started and began to feed the water to the panels. The water level stayed 1 1/2 inches above normal operating level in the sight glass. I also did not hear the water trickle back down from the panels into the tank indicating that the water did not make it up to the top of the panels. This caused the panels to continue to climb in temp until it again reached 200 degrees and the controller shut it down.
What could be causing the water to be "blocked from circulating through the panels? It should be noted that the water in the hot water tank was at 150 degrees. Plenty of hot water you say. My concern is that the pump may burn out. Any thoughts would be appreciated!
