Hello,
I'm from RI, and I have been using my GE geospring water heater since last December 2012.
Even with the coldest day up here in the Northeast, the GE geospring water heater runs 100% "heat pump" mode down my unfinished/unconditioned basement. The coldest the basement got was around 44 degrees, but the hybrid heater still able to manage to squeeze out every beat of heat from the air.
I chose it over evacuated solar tubes because National Grid Power reimbursed Rhode Islanders $1000....which is what I paid for the unit itself. So basically it's free.
so here's my question, I would like to add radiant floor heat on my 1000 square foot (first floor). Placing those PEX tubing in between the joist.
I am not planning to heat up my 2000 square foot colonial with radiant floor heating......since I already have central forced air (propane). But it would be nice to have warm floor during winter since I'll have a toddler roaming around the first floor soon (she's only 4 months now)......plus I'm hoping that radiant floor heating will save me a bit from heating bills.
I know that the GE geospring water heater will not be able to give enough juice to run the radiant floor heating.
That's why I was thinking of getting evacuated solar tubes so it can run the radiant floor heating.
Either I integrate it with my current GE geospring hybrid water heat and get a heat exchanger so I can seperate the DWH and the radaint floor heat. Or completely seperate the two systems. To just run the evacuated solar tubes directly with the radiant floor heat?
The reason why I want to integrate the evacuated solar tubes with my GE geospring hybrid water heater so I can fully utilize these tubes all year.......and not just during winter to heat my radiant floor heat. And if I integrate them, those evacuated solar tubes will definitely help my hybrid heater during winter.
so my questions are:
1.) should I integrate them or not? if yes, why? if no, why?
2.) how many evacuated tubes should I get in order to get enough BTUs to run a 1000 square foot floor with PEX radiant tubes?
3.) Are evacuated tubes be more economical/practical/ideal for my plan? or you guys just recommend another source of heat source?
4.) I thought about just buying a regular electric water heater, and use it as a heat source for that 1000 square foot radiant floor system. Its the cheapest heat source but I'm just scared of the electric bill. I know other people have done it, and they said it "warms" the floor a bit, but dont expect to heat the living area.
5.) any other thoughts?
6.) will flat plates be more economical and ideal?
thanks for the help!
