New Member in FL with DC Pool Pump question
  • Jimafter5
    • Jul 2012
    • 5
    Hi Folks,
    I joined this forum to see if anyone has experience with a DC Pool pump. I can purchase a Lorenz PS600 DC Pump/Motor
    PS 600 Controller & 3 panel kit for about $3,300 (US), but I haven't been able to find ANYONE who's actually using this or a similar system in FL. The local dealer wasn't able to give me ANY reference in my own state. I just want to hear from someone who has 1st hand knowledge that this will work as stated in the literature. Link to system (None of these are the dealer I was working with) <http://atlanticsolarpump.com/docs/ProductDataSheet_PS600.pdf> Thanks in advance!
    What's wrong with a high efficiency, 3 phase motor & pump, with a VFD controller ?
    • Jimafter5
      • Jul 2012
      • 5
      Well, Perhaps nothing... But, I'm not an expert on solar, so I thought buying a package that someone has already done their homework on would be more successful than trying to reinvent the wheel. Thanks for your thoughts.
        So you have $3K for the pump and controller, and you still have to buy the PV array.
        Also get the price for a 500- 1000 watt array (pump needs at least 340 watts to start, and PV panels only produce 80% of nameplate, like the 35MPG car really gets only 27mpg), Mounting for the array, and the conduit for the wiring.
        So, now we are up to about $6,000 to make it work, and a 10 year life on the motor, and 20+ years on the solar panels.
        • Jimafter5
          • Jul 2012
          • 5
          Actually, this is the whole kit that includes the DC pump & controller (pre-wired), (3) 185w panels, & mounting system.
            For $3K, a complete kit, it sounds amazing. Almost too good to be true.
            What happens to the pool, on cloudy days, when the pump does not run ? Do you keep an AC pump for backup ?
            • Jimafter5
              • Jul 2012
              • 5
              Yes, that's exactly right. I'll keep the AC pump in-line to use on cloudy days.
                You will have to rig it with bypass valves, or it will restrict the other pump when not in use.
                • Naptown
                  • 6880
                  You could also run them in parallel with check valves on the outlet ports of each pump.
                  • fafcosolar
                    • Aug 2011
                    • 11
                    Hi Folks,
                    In our experience, the system can run well in basic pool-only situations where features are non-existent. As soon as you add spill-overs, waterfalls, vanishing edges, spas, and other features, the system will not work effectively. Forget about solar pool heating and heat pumps for the most part. Varying flow rates will not let heating sources work effectively. Using the transformer for AC backup defeats the whole purpose. If you do decide to move forward, definitely keep your AC pump in parallel (use appropriate bypass valves and check valves).
                    As another commented, you should seriously consider a Variable Speed (VFD) pump. Pentair makes the VS-3050 and Hayward the EcoStar. These have proven to be huge money savers and are far less costly than a solar pool pump. They work great with varying flow requirements posed by features and heat sources.
                    We don't work up in your area, but I know someone who does both the Pentair product and the Lorentz Solar Pool Pump. Contact me off-forum if you want details.
                    • Jimafter5
                      • Jul 2012
                      • 5
                      Thank you for your reply. You confirmed what I suspected but I couldn't get a straight-forward answer from anybody who was selling the system. I am still interested in getting one. I have (8) 4' X 10' solar heat panels on my roof so I could run my AC pump here and there as needed to keep the temp up. I don't use the pool for half of the year anyway, so without the need for heat, the DC solar pump would provide savings there. I'm unable to contact you off-line until I have 10 posts but I am interested in your contact in my area.
                      • fafcosolar
                        • Aug 2011
                        • 11
                        Forum rules prevent me from linking to my website or email. I have private messaged you with information.
                        You should seriously consider a solar controller if you don't already have one. With a controller you can automatically turn your AC pump on when solar is available and needed. With the right logic programmed into a Pentair SunTouch controller, you can have it turn your bypass valves automatically. The trick is to turn off the Solar Pool Pump when the AC pump comes on. That can be done with a relay, too. If the guys I referred you to need help figuring that out, have them give me a call and we'll come up with a solution for you.
                        Best regards,
                        Jason Szumlanski
                        • Douggg
                          I'm in California and am thinking of buying the same system - How did it work out?
                          Hi Folks,
