That may be , but being such a stickler to take an off hand comment and try to drive home scientific requirements is foolish. I agree on the 100ft but if you look at the original post he had a very nice and very well laid out set of 5 coils 200ft each. Thais why I stated to make the manifolds with 5 200ft coils.
Help with pool heating design
intake & outlet locations
I think on a slanted platform, it would be better to have the water entering the heating pipe on the higher side and the outflow on the lower side to help the pump. Am I correct?Comment
Hi...,
Solar pool must have the high resistance polymer central body, with mixer for hot and cold water to set the perfect temperature. It must have pool filter for passing the water at least once in the day. These are some of the required conditions for designing the pools.Comment
Want to see pictures...
are there any downsides to doing all of this i like the idea of the manifold but will my pool suffer as far as water quality from bypassing the 3 jets that stream into the pool or would all be fine?
heres a quick diagram i threw together would it be something like this?
[ATTACH=CONFIG]1936[/ATTACH]
I am interested in doing something like this and want to see pictures/attachments(?), and I have to post, so I am!Comment
