hi - can anyone advise me on how to figure out what size pump would be needed to pull water out of a pool and up about 10 feet and thru a coil heater like this? I don't want to use the pool filter pump because it uses 1600 watts and would costs $1 for 5 hours of operation and I don't need to run it more than an hour a day for filtration. So I want to use a small pump (50 to 100 watts) I have found some self priming aquarium pumps that say they will pump to 13 to 16ft high but I am unsure how to figure whether there will be a friction loss problem pumping through several hundred feet of pipe. I notice that you connected the coils in series, here is a link for a similar system that connected them in parallel -
would that make the water flow thru more easily? Does anyone know how to figure this out? thanks. sherry
[QUOTE=Mike-Mat;5325]Thought you might find this interesting.
So I have 4 coils containing about 120' (each) of PVC irrigation hose, connected in series. The black PVC is mounted on a black board. Water is pumped out and thru the coils.
Preliminary Test:
Water going in is 57
Preliminary Test:
